h22 dis
My H22a has went through a distributor a year, I'm trying to figure out what would cause the distributor to fail. The first would get where the car wouldn't rev past a point, now I think the one I have now is causing the car to idle erratically and throughout the rpm range it acts if though its missing or something. Help, if you have any type of solution.
not sure....the whole distributor? or just the rotor?
not sure what it might be......but if you need a new one check.....hondadistributors.net....they have them cheap.
how old are the spark plugs / plug wires?
have you inspected your TPS, Map, or IACV sensors?
what type of ECU is running the H?
Have you Sealed the distributor properly?
Any CEL's showing up?
Come on.....we need more info than just "occasional misfire"
correct me if i'm wrong misfire is all about spark/fuel/air....
So anything affecting spark & combustion will play a factor.....(Engine choking)
Spark:
-Distributor
-Wires
-Plugs
Air:
-Intake to the cylinder
-Valves?
Combustion:
-Head Gasket
-Piston Rings
-Exhaust is plugged up
Need more info.
Spark:
-Distributor
-Wires
-Plugs
Air:
-Valves?
Combustion:
-Head Gasket
-Piston Rings
Need more info.
ejprimo
Apr 25, 2003 10:20 AM
