CEL 41 o2 sensor problem
Old Jun 5, 2008 | 02:36 PM
raidacaipo's Avatar
Default CEL 41 o2 sensor problem NEED HELP!!
Car: 97 civic hatch cx non-vtec
Motor swap: stock Jdm gsr obd2 with Jdm Ecu
Harness used: Stock 97 civic non vtec harness with modifications: Iacv fix, Iat fix, added knock sensor, added vtec solenoid, added Iab solenoid for gsr manifold
Problem:Getting Cel 41 for primary o2 sensor
Note:Secondary o2 sensor wire is NOT plugged into anything BUT primary o2 sensor IS plugged into downpipe.
Question: Why am I getting a Cel for 41 instead of a Cel for my secondary o2 sensor? I tried swapping the o2 sensors with 2 old ones and 1 brand new bosch o2 sensor. Cel still doesnt go away. Does anyone know why?
Modified by raidacaipo at 3:48 PM 6/5/2008
Old Jun 5, 2008 | 03:19 PM
raidacaipo's Avatar
Default Re: CEL 41 o2 sensor problem NEED HELP!! (raidacaipo)
Also when I was taking off my headers I forgot to unbolt the o2 sensor plugs and the wires came off the cap. Which black wires are +12 volt heater and heater ground based on the pictures?
Got the sensor grounds wired already just confused with the 2 black ones
Help please!!
Old Jun 5, 2008 | 04:27 PM
raidacaipo's Avatar
Does it matter which black wires go into the sensor plug? I know 1 is for +12 heater volt and the other is heater ground. I just dont know which one goes where because both are black wires..
Old Jun 5, 2008 | 04:52 PM
raidacaipo's Avatar
Somebody has to know!! I bet everyones watchin the Lakers game thats why.. lol me too
Old Jun 5, 2008 | 05:58 PM
v!taminb16's Avatar
LAKERS SUCK
Old Jun 5, 2008 | 08:37 PM
raidacaipo's Avatar
Default Re: CEL 41 o2 sensor problem NEED HELP!! (v!taminb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v!taminb16 &raquo;</TD></TR><TR><TD CLASS="quote">LAKERS SUCK </TD></TR></TABLE>
man lakers lost.. well get them game 2 anywayz someone help me please oh lordy lordy lordy..
Old Jun 5, 2008 | 09:07 PM
raidacaipo's Avatar
Old Jun 6, 2008 | 11:20 AM
raidacaipo's Avatar
please help someone. Im tryin to hook up the o2 sensor you see in the picture because I dont wanna have to buy a new one for now for 60 bucks..
Old Jun 6, 2008 | 08:08 PM
EgRaCeRB18C's Avatar
it could be the ground i had a problem yesterday it threw me cel 41 so i checked my wire hareness and slice some wire and regrounded it and i didnt have any cel
Old Jun 6, 2008 | 11:00 PM
raidacaipo's Avatar
Default Re: CEL 41 o2 sensor problem NEED HELP!! (EgRaCeRB18C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EgRaCeRB18C &raquo;</TD></TR><TR><TD CLASS="quote">it could be the ground i had a problem yesterday it threw me cel 41 so i checked my wire hareness and slice some wire and regrounded it and i didnt have any cel</TD></TR></TABLE>
really? I think when my radiator leaked it soaked the 2 caps for ground.. You know those 2 big cap plugs on the engine harness??? I think its blue and grey. Well what I did was take off my harness and took ALL of the black tape off.. I rechecked everywire including the o2 sensor wires.. The primary has 2 wires going to those big cap plugs. Im guessing ground. and 2 wires that go straight to the ecu. Then on the second o2 sensor theres only 1 wire that goes to the big cap thingy and 3 that goes to the ecu.
Old Jun 7, 2008 | 06:50 AM
check if your getting ground wire from the ecu inside call me it be easier to explain 407-968-9908
mxl36o
Aug 4, 2006 06:09 PM
anothersickhatch
May 15, 2004 10:22 PM
jaydm98
Dec 17, 2003 06:33 AM
Loveless
Jun 13, 2003 08:44 PM
