overheating problem.
Old Jun 5, 2008 | 07:58 AM
cvkid15's Avatar
Default overheating problem.
Hello everyone. My car has been overheating lately and its due to the fan not turning on when it needs to. I have checked the fuse for the fan and its fine. The fan only works sometimes. What could cause this? Please help its my daily. Thank you
2000 civic ex turbo single cam, no cels
Old Jun 5, 2008 | 08:42 AM
C-West Civic's Avatar
Default Re: overheating problem. (cvkid15)
Have you checked your coolant level?
Checked the Thermostat?
Ran a check on the relay?
Old Jun 5, 2008 | 09:04 AM
h2392si's Avatar
Default Re: overheating problem. (C-West Civic)
Could be a bad motor, fan relay, thermostat, fan switch, radiator cap, etc. Change the small things first like thermostat and go from there.
Old Jun 5, 2008 | 09:11 AM
cvkid15's Avatar
yeah all my fluids are good. thanks for the help. i will check the thermostat and cap and go from there
Old Jun 5, 2008 | 11:15 AM
mohater's Avatar
Compression test is the other easy check. If coolant is leaking into the header, it would force more coolant to your overflow tank and then run low after long drives.
hotcivicsi
11
Apr 9, 2009 06:19 PM
white98gs-r
Apr 5, 2009 06:51 AM
Donhonda84
Apr 4, 2007 08:36 PM
crxhftosi
Feb 22, 2005 07:53 AM
juicedricer
Jan 21, 2003 04:55 AM
