VTEC OIL LINE QUESTION.....WHY 6AN?????
Old Jun 5, 2008 | 05:56 AM
ivan93egreppin210's Avatar
Default VTEC OIL LINE QUESTION.....WHY 6AN?????
why does everyone use 6AN (3/8 inside diam.)? when tapping off the oil pressure sending unit with a tee, wouldn't it be ok to use 1/4" inside diam.? it seems like a smaller hose diam. would make a higher pressure. would it be ok to use 3/16ths or 1/4" inside diam? the oil pressure sending unit only has like a 3/16th opening to begin with. if i do use a tee, do i have to make the oil line bigger off the tee.
please do not answer unless you can give any proof to back your statement. and no im not buying the ge kit. im fabbing up an oil line kit using ss industrial grade fittings from work. thanks guys.
i posted this in the hybrid section but it only got 20 views in 24 hous so i figured i'd post it here since this forum has always been the best at getting good answers
Old Jun 5, 2008 | 06:17 AM
hybrid_KJ's Avatar
Default Re: VTEC OIL LINE QUESTION.....WHY 6AN????? (ivan93egreppin210)
You will have less pressure drop through the hose therefore flow more oil to the head.
Old Jun 5, 2008 | 08:42 AM
Default Re: VTEC OIL LINE QUESTION.....WHY 6AN????? (hybrid_KJ)
im sorry. im not sure i fully understand what you mean. could you please explain a little more?......
to me what it sounds like your saying is that the bigger the hose, the less pressure you get. so it doesnt take alot of pressure to activate vtec? how much does it need in order to work or is more pressure less important than oil volume?
Old Jun 5, 2008 | 09:17 AM
Rocket's Avatar
What is the size of the oil hole on the VTEC head (the one that gets tapped and plugged)?
This will answer y0 question.
Old Jun 6, 2008 | 08:39 AM
Default Re: VTEC OIL LINE QUESTION.....WHY 6AN????? (Master of the Universe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Master of the Universe &raquo;</TD></TR><TR><TD CLASS="quote">What is the size of the oil hole on the VTEC head (the one that gets tapped and plugged)?
This will answer y0 question.</TD></TR></TABLE>
that makes total sense. so using 1/4 id tubing should be ok right?
Old Jun 6, 2008 | 09:04 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Furyof4 &raquo;</TD></TR><TR><TD CLASS="quote">If you use a tee at the oil pressure switch for a feed, your pumping unfiltered oil into the head.</TD></TR></TABLE>
how true is this^^^^^^^^^^
tiemze
Jun 15, 2014 07:58 PM
tuhboek
Jun 21, 2010 05:51 AM
ivan93egreppin210
Jun 11, 2008 12:04 PM
newstyd
Jun 16, 2003 10:56 AM
RyanAutry
Feb 4, 2003 09:43 PM
