Miss fire
Old Jul 16, 2002 | 05:02 PM
B18C-RnVA's Avatar
New User
Default Miss fire
can you guys tell me what are some symptons that my engine may be miss firing
Old Jul 16, 2002 | 05:45 PM
BreakStuff's Avatar
New User
Default Re: Miss fire (B18C-RnVA)
Spark plugs, plug wires, dist. cap/rotor, coil(s), fuel quality/quanity, cam and crank sensors, did I miss any?
Old Jul 16, 2002 | 06:09 PM
B18C-RnVA's Avatar
New User
Default Re: Miss fire (BreakStuff)
yeah im talking about symptons while driving that my car is miss firing??
Old Jul 16, 2002 | 06:23 PM
BreakStuff's Avatar
New User
sorry, my bad..
misfire while driving, motor spits, sputters, coughs, yacks ,farts ,burps ,misses a step, bites the big one, symptoms most noticeable on acceleration, checking for any codes even if the CEL is not illuminated would be a good start...
Old Jul 16, 2002 | 06:43 PM
Mover's Avatar
Under acceleration ? between gearshifts ? lifting the throttle ? When does it happen most ? ( faulty spark plug wire.??) Need more info.
Old Jul 16, 2002 | 07:08 PM
BreakStuff's Avatar
New User
Default Re: Miss fire (Mover)
Acceleration like when you take off from a start, most likely from standstill and accelerating in first gear.. de-acceleration and any engine load between shifts are not a good determining spot of an engine mifire.. but I could tell you that an electrical related component,( plugs,cap,rotor,wires,coil) will misfire more noticeably when the car is hotter.. heat=resistance...
Old Jul 16, 2002 | 07:36 PM
kinesistech's Avatar
Unless you have a chipped ecu any misfire should throw a code. It will feel like its running on three cylinders, like it cant get out of its own way. Acceleration will suffer. If you have a turbo, I recommend doing a compression test if you think there may be any problems.
gerbsgsr
15
Dec 28, 2015 08:46 PM
leon1990
Jul 7, 2012 01:00 PM
Civic Hybrid
10
Aug 17, 2008 09:35 AM
wierdo
Feb 2, 2004 11:19 PM
