h22a4 cylinder help!
Old Jun 4, 2008 | 06:53 PM
civictuner91's Avatar
Default h22a4 cylinder help!
hello
I have a h22a4 and am looking into boosting it soon. what im wondering is since the a4 is an open deck block, should i use a blockguard to toughen it up a bit? or should i sleeve the cylinders? both? is there any good pistons that wont scar up the cylinder walls like forged pistons do? i want to run about 15 psi.
Old Jun 4, 2008 | 07:03 PM
DfwBB6's Avatar
Default Re: h22a4 cylinder help! (civictuner91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictuner91 &raquo;</TD></TR><TR><TD CLASS="quote">hello
I have a h22a4 and am looking into boosting it soon. what im wondering is since the a4 is an open deck block, should i use a blockguard to toughen it up a bit? or should i sleeve the cylinders? both? is there any good pistons that wont scar up the cylinder walls like forged pistons do? i want to run about 15 psi.</TD></TR></TABLE>
a. blockguard NO....once again the sleeves arent the ones that are that fragile its the ringlands
b. Psi means nothing depends on what turbo you are running
c. If u plan on running forged pistons you have to sleeve your block, unless you wanna go with the alternative mahles but used with mixed results.(search there is a thread about them somewhere)
Old Jun 4, 2008 | 07:11 PM
Ihad a smaller turbo i was thinking about.. it hada 48 trim on the housin A/R and the turbine is 76 trim and .64 exhaust housing A/R (im not too sure about these numbers had them written down from garretts site) and this setup was planned to run about 8-10 psi. now i want to run something bigger maybe a 50-60 trim for the housing A/R and the turbine 76 trim and .82 exhaust housin A/R. so what can i do to make my block withstand
Old Jun 4, 2008 | 07:13 PM
*this
Old Jun 4, 2008 | 07:14 PM
DfwBB6's Avatar
Default Re: (civictuner91)
here is the mahle thread https://honda-tech.com/zerothread?id=1406865
here the h22 turbo thread https://honda-tech.com/zerothread?id=316373
Old Jun 4, 2008 | 07:21 PM
so you think if i leave everything stock maybe shot peen the rods or something drop the cr to like 9- 9.5 it can take boost well?
Old Jun 4, 2008 | 07:24 PM
DfwBB6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictuner91 &raquo;</TD></TR><TR><TD CLASS="quote">Ihad a smaller turbo i was thinking about.. it hada 48 trim on the housin A/R and the turbine is 76 trim and .64 exhaust housing A/R (im not too sure about these numbers had them written down from garretts site) and this setup was planned to run about 8-10 psi. now i want to run something bigger maybe a 50-60 trim for the housing A/R and the turbine 76 trim and .82 exhaust housin A/R. so what can i do to make my block withstand</TD></TR></TABLE>
depending on your goals and how good your tune is your stock block will be fine, but again these options are very subjective depending on your goals.....how soon you want to spool etc etc. Small turbo will produce less HP at same Psi compared to a bigger turbo. In my opinion a 57 trim would be ok, now you could go bigger but sacrifice spool times.
Old Jun 4, 2008 | 07:26 PM
DfwBB6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictuner91 &raquo;</TD></TR><TR><TD CLASS="quote">so you think if i leave everything stock maybe shot peen the rods or something drop the cr to like 9- 9.5 it can take boost well?</TD></TR></TABLE>
How do plan on lowering compression? If u r planning to drop the compression using headgasket i think not a good idea
Old Jun 4, 2008 | 07:28 PM
yeah i kinda want a quick spool max hp is not my highest concern.. tuning will be very good there is a good shop where i can get it tuned. im worried because this is my DD as well
Old Jun 4, 2008 | 07:30 PM
cant you get these mahle pistons with a lower cr?
Old Jun 4, 2008 | 07:32 PM
DfwBB6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictuner91 &raquo;</TD></TR><TR><TD CLASS="quote">cant you get these mahle pistons with a lower cr?</TD></TR></TABLE>
yes u can.....this is going to be a daily driver u realized there is going to be some machining done to your block to accommodate those pistons???? meaning taking the engine out of the car and some downtime involved
Old Jun 4, 2008 | 07:34 PM
alright so with lower c/r mahles it is. thanks
Old Jun 5, 2008 | 05:10 AM
flyrod's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictuner91 &raquo;</TD></TR><TR><TD CLASS="quote">i want to run about 15 psi.</TD></TR></TABLE>
That will be a bit iffy on a stock block.
Old Jun 5, 2008 | 02:53 PM
Needy4Speed's Avatar
Default Re: h22a4 cylinder help! (DfwBB6)
I brought my brand-new, stock block in to D&G Motors a couple of days ago, along with my crank, type S pistons/rods, flywheel, etc. to be balanced and mapped. The owner there really knows his **** with these motors, and I talked with him for a while on forced induction. Apparently, he's ran these motors with stock pistons, rods, blocks/cylinders...all but stock valve trains and had no problem running 15-18 pounds of boost, pushing over 400 WHP. He also said that the H22A blocks are not good sleeved. I can get more details from him if you want.
Old Jun 5, 2008 | 05:44 PM
DfwBB6's Avatar
Default Re: h22a4 cylinder help! (Needy4Speed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Needy4Speed &raquo;</TD></TR><TR><TD CLASS="quote">He also said that the H22A blocks are not good sleeved. I can get more details from him if you want.</TD></TR></TABLE>
wow, H22a blocks aren't good sleeved? please tell me this is a typo
Old Jun 6, 2008 | 06:41 PM
yeah taking the engine out is no big deal.. I think he meant h22a4 are not good sleeved.. what do you reccomend i do to the block to be able to handle 15 psi reliablely? I think i might be good with stock perhaps shot-peened rods right?
Old Jun 10, 2008 | 08:16 PM
What about valvetrain? is everything there ok stock? Boost doesnt affect much up there right? im sticking with everything stock up there for now..
Old Jun 10, 2008 | 08:20 PM
yeah i would like to get in touch with him. i want to clarify my setup with someone knowledgable.
Old Jun 11, 2008 | 02:52 PM
H24Turbo's Avatar
whoever said the h22 block is not good sleeved is wrong! go look in the high horse power H series motor thread in the FI forum. you'll see setups there and most are sleeved. at least the ones I've read are and my H22A4 block has eagle sleeves. you'll see my setup to...
Old Jun 11, 2008 | 03:22 PM
DfwBB6's Avatar
Default Re: (H24Turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H24Turbo &raquo;</TD></TR><TR><TD CLASS="quote">whoever said the h22 block is not good sleeved is wrong! go look in the high horse power H series motor thread in the FI forum. you'll see setups there and most are sleeved. at least the ones I've read are and my H22A4 block has eagle sleeves. you'll see my setup to...</TD></TR></TABLE>
r u serious? who said that? and where?
Old Jun 11, 2008 | 05:28 PM
well if the h's are good sleeved why did you sleeve yours. you just contadicted yourself.
Old Jun 11, 2008 | 05:30 PM
DfwBB6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictuner91 &raquo;</TD></TR><TR><TD CLASS="quote">well if the h's are good sleeved why did you sleeve yours. you just contadicted yourself.</TD></TR></TABLE>
hahaha i know thats statement didnt make the least bit of sense
Old Jun 11, 2008 | 05:33 PM
anyway.. do you think my stock block w/low cr mahles can handle a fair bit of boost? thanks so far
Old Jan 13, 2010 | 08:19 PM
javier's98coupe's Avatar
New User
Ok fellas, I am new here but I am putting an h22a4 to my 98 coupe. If I wanted to turbo this with everything stock. What kind of turbo could I use and what is the max psi wowuld I be able to boost without blowing my engine. Thank you for your input!
Old Jan 14, 2010 | 06:37 AM
Jimster480's Avatar
PSI means nothing. running 15PSI on a 16g would be fine, but if you want to run 15PSI on a big turbo thne our going to be pushing it.
seldon
11
Sep 17, 2008 04:42 PM
civictuner91
Jun 6, 2008 06:43 PM
flatblackintegragsr
Feb 24, 2008 10:52 AM
bjfisher
Dec 19, 2004 06:58 PM
InsertCleverSN
Apr 27, 2003 06:41 PM
