h22a4 cyllinder help!
Old Jun 4, 2008 | 07:00 PM
civictuner91's Avatar
Default h22a4 cyllinder help!
hello
I have a h22a4 and am looking into boosting it soon. what im wondering is since the a4 is an open deck block, should i use a blockguard to toughen it up a bit? or should i sleeve the cylinders? both? is there any good pistons that wont scar up the cylinder walls like forged pistons do? i want to run about 15 psi.
Old Jun 4, 2008 | 09:45 PM
Obama's Avatar
Default Re: h22a4 cyllinder help! (civictuner91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictuner91 &raquo;</TD></TR><TR><TD CLASS="quote">hello
I have a h22a4 and am looking into boosting it soon. what im wondering is since the a4 is an open deck block, should i use a blockguard to toughen it up a bit? or should i sleeve the cylinders? both? is there any good pistons that wont scar up the cylinder walls like forged pistons do? i want to run about 15 psi.</TD></TR></TABLE>
Your coming at this all wrong. First off forget about the 15psi, its irrelevant. It's a matter of how much power you want to make; Without sleeving the motor, most I'd shoot for is ~340. But for anything more than that I would suggest getting the block sleeved (only way to use aftermarket pistons, besides mahle.) Oh yeah, ditch the blockguard idea
Right now I'm at 471/394, built block/stock head
Old Jun 5, 2008 | 04:01 AM
H24Turbo's Avatar
a block guard is almost pointless sleeve your block. if you decide to sleeve it the H22A4 becomes a semi-closed deck and is pretty much bullet proof. as far as pistons i recommend cp or je.
Old Jun 6, 2008 | 06:43 PM
thanks guys i think i might keep stock sleeves and get a set of mahles it seems like the most obvious solution.. yeah those numbers sound good mid to low 300 is more than enough
civictuner91
Jan 14, 2010 06:37 AM
flatblackintegragsr
Feb 24, 2008 10:52 AM
AgentJam
Apr 26, 2004 05:48 AM
InsertCleverSN
Apr 27, 2003 06:41 PM
p10hlm
Jan 7, 2003 11:25 PM
