msd ignition
i got a 95 del sol with a 2000 si b16 built with everything but sleeves and a block guard i got a full msd ignition setup the dist., 8.5 mm wires, ignitior, and the ss blaster external coil. the problem is it wont start my car, if anyone knows wat to do or wat i can check appreciated. wat ive done so far is hooked the coil up to a friends car and it started fine, wen its in my car i got power to everytrhing just no spark outta the wires o and i got ngk irridum plugs so thanks if u can help
most likely it is your wires. when you swapped the coil to a friends car do you mean you put your msd distributor and coil up? Before I went back to a stock distributor I had the same thing - changed spark plug wires and it worked fine (I was getting some spark but only running on 1 cylinder)
go to somewhere like advance and get a cheap set of low resistance spark plug wires - willing to bet you got bad wires...If it isn't your wires it is either your ignitor or your distributor. I have each seperate if you end up needing and will sell them cheap.
ignitor I'd prob charge ya like 20 or would give ya the ignitor and msd distributor needing rebuilt for like 50-60 + shipping has good cap with it...I have the 6 al box w/ 8k rev limit chip in it and and blaster 2 coil w/ bracket also
HatchBlakKidd
Jun 30, 2011 09:29 AM
