cluster not working... HELP!!!
Old Jun 4, 2008 | 09:41 AM
TYL3R's Avatar
Default cluster not working... HELP!!!
i recently got a del sol (on saturday) and the speedo, tach and odometer dont work. how could i check to see if the cluster is good and it is something else? i checked the connections behind the cluster and everything was good, so could it possibly just be the cluster??
Thanks
Old Jun 5, 2008 | 09:43 AM
TYL3R's Avatar
Default Re: cluster not working... HELP!!! (TYL3R)
bump
Old Jun 5, 2008 | 10:34 AM
GottaB20man's Avatar
Did you try checking your fuses under the hood? It may be your speed sensor also..
Old Jun 5, 2008 | 11:58 AM
apexi_rsx's Avatar
tach would work if the speedpp was bad thought because that runs off your coil/distributor. check fuses first. then u might have to unplug it and get a voltage tester and see if its getting power
Old Jun 5, 2008 | 12:21 PM
dustinO's Avatar
sounds like a bogus cluster to me
if all the connections are solid then it should "usually" work.
Old Jun 6, 2008 | 10:02 AM
TYL3R's Avatar
thanks
static-x
Aug 14, 2008 08:07 AM
aziaticvang
Jan 8, 2008 06:41 PM
civiccpedx
May 18, 2007 06:56 PM
EK SQUAD 425
May 10, 2006 03:28 AM
carlos
10
Oct 15, 2002 08:57 PM
