cluster not working... HELP!!!
i recently got a del sol (on saturday) and the speedo, tach and odometer dont work. how could i check to see if the cluster is good and it is something else? i checked the connections behind the cluster and everything was good, so could it possibly just be the cluster??
Thanks
Thanks
tach would work if the speedpp was bad thought because that runs off your coil/distributor. check fuses first. then u might have to unplug it and get a voltage tester and see if its getting power
EK SQUAD 425
05-10-2006 03:28 AM
