wierd problem im having on the ek....
Old Jun 3, 2008 | 05:51 AM
spooncivic99's Avatar
Default wierd problem im having on the ek....
well i recently swapped out a busted motor on the ek and after the swap my clutch pedal pressure has been real light. i feel as if its a dead pedal or something but everytime you depress it it comes back up, ive bleed it and when you bleed it instead of a steady stream of brake fluid i end up getting a strong spray(dont know if that is normal). Anyone else have this issue, chime in please. Oh and btw clutch is fairly new as in 10k and less.
Here is my other problem, could be associated with the problem above also but i am completely loss so it could be anything. When i go to accelerate the car tends to shake and bog down in the lower rpm's and then as it passes the 2k range it starts to run fine. it only happens as you slowly accelerate. its gotten new plugs and wires, the only thing i could think of thats holding it back is maybe a problem with fuel delivery. chime in please if you know of any possible ideas!!!
Thanks..
Old Jun 4, 2008 | 08:28 AM
Default Re: wierd problem im having on the ek.... (spooncivic99)
bump for some help...
jdm_ek_noob
Sep 8, 2013 06:36 PM
KhornLuda
Aug 7, 2006 05:19 PM
mattymatt
Nov 9, 2004 09:12 AM
SleepnCiViC
16
Dec 1, 2003 07:02 AM
