injector driver problem.. my woes never cease to exist
Old Jun 2, 2008 | 03:12 PM
THEDirtyDseriesWOOT's Avatar
Default injector driver problem.. my woes never cease to exist
ok well im driving down the road in my rhd del sol .. and it just dies so i pop the hood and the stock o2 sensor was melted to the DP and it was smoking rther back on the harness... so i push it home i was like a block away..
well i get it fixed up so i thought and its not getting fuel so i rewire all the injectors independently to the ecu..
1000cc precisions with dsm resistor box..
it cranks but #3 isnt pulsing..
so i check the wire at the ecu A5 and i ground it with a noid light and yah it clicks so i know i have power and the wiring is good now..
but it still wont pulse from the ecu..
btw its p28 with hondata s300
so i jump it to the #1 cylinder injector and the car rund good WHILE injector error is disabled.
so im like ok the driver is [freak]ed so i search and i get a old obd1 nonvtec auto ecu i have laying around and i desolder the STA 413A and put it into my P28 thinking that this is the injector driver .. well same thing it works good when jumped ,but like *** wired correctly..
so does anyone know if there is more to the injector drivers than that one chip..
because im broke at the moment ..
and i cant afford another p28..
im scared to run the car with the inector jumped i know its the closest to the right fire order, but im sure the timing of the fuel delivery is gonna be off a bit and that could mean detonation in a turbo car??
ANY INFO AT ALL would be helpful thanks
-Blake
Old Jun 2, 2008 | 03:27 PM
ok guys searching on pgmfi i found that qm1 and qm2 are the drivers.. STA 460c ill try to desolder those and ill tell you how it goes
Old Jun 2, 2008 | 05:28 PM
well i tried it and still NADA...
anyone have any ideas... hondata s300 maybe f-ed ?
Old Jun 2, 2008 | 07:10 PM
norconex's Avatar
Default Re: (THEDirtyDseriesWOOT)
The S300 cant make your ECU do that...its the ECU, you need another
Old Jun 3, 2008 | 03:57 AM
thanks ill try to scroundge one up
Old Jun 3, 2008 | 07:42 PM
i went over the solder points on qm1 and qm2 on the ecu that i replaced and it works now so for those who need to know if they burn out find an aol shitty ecu and steal them from it its alot cheaper!
lsvtek
15
Jul 10, 2012 02:28 PM
jm2000turbo
Dec 1, 2011 04:24 PM
codyw
Apr 29, 2010 02:23 PM
mickey b16
May 26, 2009 04:02 PM
TURBO DC2
May 28, 2005 10:41 AM
