engine swap
Hy i have a integra with a b18c engine and I wanna put a type r engine b18c R in the car do I have to change things or it will be the same?
If you B18C1 is OBD-2, there is no difference. If your B18C1 is OBD-1 you'll have to reuse your OBD-1 injectors or splice in the OBD-2 injector harness (plugs are different) and you'll have to reuse your OBD-1 VTEC distributor. Also, if you are OBD-2 I would suggest getting a P73 ECU or a VTEC controller. 4400rpm for ITR cams is a terrible VTEC crossover. If you are running OBD-1, you can use the P72 ECU but I recommend chipping it with a higher redline and VTEC crossover.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dplatt »</TD></TR><TR><TD CLASS="quote">If you B18C1 is OBD-2, there is no difference. If your B18C1 is OBD-1 you'll have to reuse your OBD-1 injectors or splice in the OBD-2 injector harness (plugs are different) and you'll have to reuse your OBD-1 VTEC distributor. Also, if you are OBD-2 I would suggest getting a P73 ECU or a VTEC controller. 4400rpm for ITR cams is a terrible VTEC crossover. If you are running OBD-1, you can use the P72 ECU but I recommend chipping it with a higher redline and VTEC crossover. </TD></TR></TABLE>
thats why you should really just get the matching ECU lol
Sure, if the motor comes with a complete OBD-2 harness but most are hacked from quick engine pulls over in Japan. I have never received a motor with an uncut harness. So if he has an OBD-1 harness, he'll have to make it work with the OBD-1 ECU (or run an OBD-1 to OBD-2 Conversion harness). Something else I forgot to mention is that You'll need a new air intake pipe. The GSR version will not work with the ITR manifold.
Cap'N Chronic
24
Mar 8, 2014 09:30 AM
jdmbuilt
17
Jun 25, 2003 06:16 PM
