Turbo car With Cat
i have a 93 civic with a GSR turbo swap, and it still has the cat on it, if i cut it off will it boost more?? and if so how much more?? I know it should spool quicker.
any help is appreciated... thanks
It should not boost more. I was boosting 10psi on my stock 2.25in exhaust then I went with a full 3in exhaust and it boosted the same but spooled faster. I did not have it retuned after I did this and the ringlands went out on all of the pistons. I was making 280 at 10psi with a 60trim. With the 3in and new motor it was making 320 at 10psi so you can see how much a restriction it was and why I needed to retune.
If you tuned the car with the cat on make at least make sure the air/fuel is fine after you take it off.
