civic dx to si conversion
Old Jul 16, 2002 | 10:20 AM
thecaptain's Avatar
Default civic dx to si conversion
Hi folks
Need some technical help. Am putting an 89 SI engine into an 89 DX. Did the wiring mods as listed in Kenji's article. But, when turning the key the main relay chatters. This is the relay that powers the fuel pump.
Any ideas?
Thanks
Ron
ronspencer@nc.rr.com
Old Jul 16, 2002 | 10:57 AM
kenji's Avatar
25 Year Member
Default Re: civic dx to si conversion (thecaptain)
Check to make sure the PGM-FI ground on the engine harness is tightened down on the thermostat housing.
Also, check all of the other engine grounds. That should solve your problem.
Good luck.
-kenji
Old Jul 16, 2002 | 11:41 AM
civicwagonman's Avatar
Default Re: civic dx to si conversion (kenji)
yes and check the ground from transmission to framerail/battery. I have forgotten to hook this up on two different swaps and caused problems.
berts95ej
Jul 14, 2007 07:41 PM
ericracingpr
Jan 19, 2007 02:16 PM
h8tred
10
May 2, 2003 07:44 AM
thecaptain
Jul 16, 2002 12:51 PM
