Oil vapor from catch can????
Old May 31, 2008 | 03:20 PM
AK94GSR's Avatar
Default Oil vapor from catch can????
it seems at idle i have alot of vapor that comes out of my catch can. im using the endyn setup. have one line on the back of the block going to a top port.the drain on the bottom back to the other port on the back of the block. i also hooked up the valve cover stock port ran to the other top port of the catch can
has anyone had this issue??
Old May 31, 2008 | 03:40 PM
blackeg's Avatar
Default Re: Oil vapor from catch can???? (AK94GSR)
i have some smoke/vapor that comes out at idle too, especially when the motor is cold. im using the z10 setup. i think its relatively normal. i wouldnt worry unless u have bad compression or high leakdown
Old May 31, 2008 | 07:43 PM
blinx9900's Avatar
Default Re: Oil vapor from catch can???? (blackeg)
welcome to owning a catch can its normal fo sho.
Old Jun 1, 2008 | 02:32 AM
DaveF's Avatar
Default Re: Oil vapor from catch can???? (blinx9900)
see video
Old Jun 1, 2008 | 05:34 AM
Alfa Turbo's Avatar
Default Re: Oil vapor from catch can???? (DaveF)
One of the by products of combustion is water.
It looks like water vapor, I wouldn't have any worries.
Old Jun 1, 2008 | 06:49 AM
AWDstylez..'s Avatar
* B A N N E D *
It's completely normal. Hot crankcase gases hitting cooler air = vapor
preludeNApower
Mar 18, 2012 07:21 AM
petwhookie
69
Mar 12, 2010 03:50 PM
accord99power
Mar 5, 2010 05:43 AM
dont_tri
Jul 11, 2008 08:43 AM
hybrid901
Jan 3, 2002 11:03 AM
