rev limiter at 4500
Old May 31, 2008 | 05:43 AM
drowzysleeper's Avatar
Default rev limiter at 4500
i got and ls swapped e g and the tak is a lil off. i hit my rev limiter at 4500 rpms wtf. also its got cams and valvetrain. stock ecu what could cause this? ne help would be graet also im not throwing ne codes.
Old May 31, 2008 | 06:20 AM
gibsanez's Avatar
Default Re: rev limiter at 4500 (drowzysleeper)
What cams and valvetrain are in the engine?
Old May 31, 2008 | 06:43 AM
Default Re: rev limiter at 4500 (gibsanez)
crower stage 2 cams with dh valve train
Old May 31, 2008 | 07:38 AM
gibsanez's Avatar
Well considering you're running a stock ECU with a tune for cam's MUCH smaller than those, that could be one of your problems.
Old May 31, 2008 | 08:09 AM
blakk91's Avatar
Not going over 4500 RPM'S complys with you being in "Limp Mode". Limp mode is based timing/fuel seting because if an enine fault the ECU has found. So to protect itself it will not go over 4500 RPM"S and run rich with no timing. Check The codes even tho there is no CEL. Then get back with the code reselts. Visualy check connectors on your engine harness/wires for cut/unhooked wires/harnesses.
Old May 31, 2008 | 10:19 AM
Default Re: rev limiter at 4500 (blakk91)
i am not throwing any codes checked anyway and no codes. no wires are unhooked. i'm not sure wtf is going on.i thought i would have a cel if i was in limp mode? anyone else have any suggestions?
Old Jun 1, 2008 | 08:49 AM
bump help please
Old Jun 1, 2008 | 10:11 AM
.Hatches.'s Avatar
ur in limp mode. get a tune
Old Jun 2, 2008 | 11:51 AM
Default Re: (.Hatches.)
WITHOUT A TUNE IS THERE ANYTHING I CAN DO AND WHERE CAN I GET CHROME PRO AND EVERYTHING NEEDED?
Old Jun 2, 2008 | 01:45 PM
gibsanez's Avatar
Default Re: (drowzysleeper)
Just talk to whoever will be dyno tuning your car.
Old Jun 2, 2008 | 02:37 PM
Default Re: (gibsanez)
after driving a few more times i have came to a conclusion that i am rapping out the rpms my tak is just way off. the only problem i got is that the car will not idle after it warms up it was an auto that was converted to manual could it be something wired wrong i didnt do the conversion it was already done when i bought the car.
Old Jun 2, 2008 | 06:05 PM
bump
Old Jun 3, 2008 | 07:07 PM
4GE4YA's Avatar
Its probably due to the fact that it has cams and is not tuned. Depending on what cams you have. The map sensor is probably not reading enough vaccum which in turn ups the injector duty cycle.
Old Jun 4, 2008 | 04:08 PM
Default Re: rev limiter at 4500 (4GE4YA)
ok im planing on geting a crome chipped ecu i tell them what i have and the chip it with a basemap. its from pheariable.net is that good?
Old Jun 6, 2008 | 01:26 PM
finally threw a cel it was 43 which is fuel system im guessing i need a new pump or injectors already changed the filter ne1 got any ideas
Old Jun 7, 2008 | 03:20 AM
gibsanez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drowzysleeper &raquo;</TD></TR><TR><TD CLASS="quote">ok im planing on geting a crome chipped ecu i tell them what i have and the chip it with a basemap. its from pheariable.net is that good?</TD></TR></TABLE>
It's good enough to get you to the dyno. It's not good enough to run around on the street with.
krazy newbie
13
Jan 12, 2010 05:20 PM
89eFRACER
12
Apr 13, 2006 09:21 PM
beeroh
Sep 24, 2004 08:16 AM
Pfieff
Aug 31, 2003 05:23 PM
MeanGreenEG9
Dec 4, 2002 07:58 AM
