obd2 ls swap problems
Old May 30, 2008 | 02:07 PM
knuckk's Avatar
Default obd2 ls swap problems
so have a 97 ek coupe I had a ls vtec swap in there I took out the swap and put in 96 ls swap I got the stock ek engine harness but now the motor just keeps crankinn it won't turn over I just changed the spark plugs and wires someone told me it could be dizzy rotor if u guys don't think that's it help mee out
Modified by knuckk at 4:51 PM 5/30/2008
Modified by knuckk at 12:00 PM 5/31/2008
Old May 31, 2008 | 09:58 AM
knuckk's Avatar
bumppppppppppp
Old May 31, 2008 | 10:00 AM
IOSUA's Avatar
Default Re: (knuckk)
im just wondering, how did you put the integra harness on your EK??? it doesnt even plug up..
Old May 31, 2008 | 10:58 AM
knuckk's Avatar
i meant stock ek harness sorry
does anyone think it might be the dizzy?
Old May 31, 2008 | 11:15 AM
geebs's Avatar
do you have spark? do you have fuel? all your grounds good?
Old May 31, 2008 | 12:29 PM
knuckk's Avatar
yea my grounds and fuel is good but i dont know about spark yet how can i check it?
Old May 31, 2008 | 12:37 PM
IOSUA's Avatar
take a spark plug wire out and set it on the core support. have a friend crank the motor while you look for a spark. if you dont have a spark then it might be your cap and rotor. also check your timming too
Old May 31, 2008 | 02:09 PM
knuckk's Avatar
Default Re: (IOSUA)
just found out its a bad connection problem with my dizzy its not getting any spark but its def getting fuel
Emmanuelsdd
Apr 19, 2012 07:57 AM
tigmandick
19
May 21, 2010 10:13 PM
aaron_morris
May 12, 2009 03:14 PM
ekb16a
Mar 23, 2008 03:05 PM
chicows18
Apr 24, 2006 04:27 PM
