engine swap motor mounts help
Old May 30, 2008 | 01:01 AM
just getting started's Avatar
Default engine swap b18ls from92 teg into 93 civic rear mount questions?????
i have a 93 civic 4 door and i put in a b18ls from my wrecked 92 integra in and the back mount is in but i had to turn the mount backwards and could only use two of the three mounting holes is ther a place i can buy mounts that are right or am i going to have to fab one up myself
Modified by just getting started at 12:27 AM 6/3/2008
Old Jun 3, 2008 | 02:46 PM
vtecb18c's Avatar
Default Re: engine swap b18ls from92 teg into 93 civic rear mount questions????? (just getting started)
you may need a mount from a 99-00 si...and you may need half of the driver side mount from an si too....the one that has the 2 bolts sticking up
Old Jun 3, 2008 | 03:02 PM
nix94delsol's Avatar
Default Re: engine swap b18ls from92 teg into 93 civic rear mount questions????? (vtecb18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb18c &raquo;</TD></TR><TR><TD CLASS="quote">you may need a mount from a 99-00 si...and you may need half of the driver side mount from an si too....the one that has the 2 bolts sticking up</TD></TR></TABLE>
you would need those mounts for an "ek" style civic
OP your going to either need mounts out of a 94-01 integra or your going to have to get aftermarket mounts
http://www.hasport.com
Old Jun 3, 2008 | 03:24 PM
JDM_902's Avatar
Default Re: engine swap b18ls from92 teg into 93 civic rear mount questions????? (nix94delsol)
You dont need different "mounts" you need different "brackets" for a B series into a 5th gen. Integra rear "L" bracket. That's all I'm 100% sure about, I'm sure more people will chime in with some good advice.
Old Jun 9, 2008 | 01:38 AM
Default Re: engine swap b18ls from92 teg into 93 civic rear mount questions????? (JDM_902)
so whats the diff between the rear brackets do u know
and thanx for your info i will look into that
Old Jun 9, 2008 | 04:50 AM
wright54's Avatar
You will also need the front lower mount from a 94-01 teg (I am talking about the mount that bolts to the side of the trans and then bolts to the underside of the frame). If you are going to keep A/C in the car you will need the A/C bracket from the SI Vtec del sol because it will allow the D-Series compressor to bolt up.
HOUSTONb
Dec 23, 2008 04:24 PM
92CiviC4dr
Mar 2, 2006 08:04 AM
jadsi420
Aug 11, 2005 07:16 AM
Got Utensils
Mar 18, 2004 05:08 AM
Propulsion
Mar 11, 2002 10:57 PM
