stock d16z6 sleeves
Old May 29, 2008 | 04:39 AM
93gspeccivic's Avatar
Default stock d16z6 sleeves
i have upgraded the internals on my d-block to hold 25+ psi. what is the max psi the stock sleeves can hold?
Old May 29, 2008 | 08:05 AM
HiProfile's Avatar
Default Re: stock d16z6 sleeves (93gspeccivic)
Read the FI FAQ that's stickied on the top of this forum. Don't skim the topics and read what you think will have JDM pictures in them, read everything.
You don't hold "psi", unless you're refering to the maximum turbo a class, such as SFWD, can utilize. You either max out pump gas, or run too much power. A T3 turbo could make 350whp at 26psi with a perfect intercooler, while a t3/t67 could make 500whp with 24psi - 500whp worth of air in your motor will create much higher cylinder pressures than 350whp worth.
In other words, tell us what your goals are, what turbo you have if you already got one, and we'll tell you the most you can expect. People have made 400whp on a bone-stock Z6, and some have blown up their fully-built Z6 with 150whp.
Old May 29, 2008 | 06:35 PM
i just have a 60 trim garrett t3/t04, eagle rods, wiseco pistons compression 8.5:1, stock head..... im realy trying to make as close to 400whp as possiable if not a little over. open to suggestions
Old Jun 4, 2008 | 05:25 AM
bump, does anyone know how many psi i can run with this set up?
Old Jun 4, 2008 | 05:28 AM
quicksilver1689's Avatar
i ♥ snails
hmmm sounds like ur approaching this the wrong way, take it a tuner, have him do the tuning say my goal is 400whp on this car, here is my setup, psi will be a function of the turbo system and engines efficiency and power level, stop thinking psi
Old Jun 5, 2008 | 11:11 AM
JDM-JAMES's Avatar
new max record on stock sleeves is 477hp but all sleeves arnt the same
Old Jun 5, 2008 | 11:14 AM
1995Civic's Avatar
Default Re: stock d16z6 sleeves (JDM-JAMES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-JAMES &raquo;</TD></TR><TR><TD CLASS="quote">new max record on stock sleeves is 477hp but all sleeves arnt the same</TD></TR></TABLE>
Where can this be found?
I've seen higher, however I would never take the risk w/ that much power on stock sleeves. If you obviously have the money to make that much power, why not make that much power the safe(r) way?
Bipolarcivic
Aug 7, 2013 05:36 AM
projectef
Jun 1, 2008 06:46 PM
ieatpaint315
Jun 29, 2007 05:21 PM
OrangeBoost
Sep 26, 2005 10:46 AM
raiden571
Jun 18, 2005 11:38 AM
