turbo choices
Old Jun 17, 2005 | 04:33 PM
raiden571's Avatar
Default turbo choices
ive been boosted for a couple months now at 10psi on my z6. its fun, but i want more. i dont feel safe upping the boost on the on a stock motor. i can getg ahold of wiseco pistons cheap and tuner toys rods.
what would be a good size turbo for my setup? i wanna run 1bout 15-18 psi. any thoughts are great thanx
Old Jun 17, 2005 | 04:58 PM
s2kdre's Avatar
Default Re: turbo choices (raiden571)
look into precision turbos, but if you're gonna redue the motor you need to sleeve it because the d series sleeves are weak and over 10 psi they shift causing headlift.
Old Jun 18, 2005 | 08:02 AM
raiden571's Avatar
im not wrried about head lift to much. im gonna use new arp ****, and plenbty of guys run above 10 psi and are fine. hell, ive seen stock motors run 13psi and do fine. just wanted some opinions on turbos
precisions are nice, but the ones that ive seen all look way to big, my little d wouldnt spool a slug like that for a while. i was thinking of some sort of t3/t4
Old Jun 18, 2005 | 08:59 AM
Blue98Ex's Avatar
Default Re: (raiden571)
Might wanna try the t3/t4 .50 trim or the .57 trim...
Old Jun 18, 2005 | 11:38 AM
Juggernaut 2's Avatar
Check out the specs of a precision sc44 for your setup.
crvb20z
14
Apr 15, 2009 01:00 PM
chocolatesk8er10
Oct 11, 2008 10:21 PM
andyvaj
Mar 11, 2007 11:49 AM
BoostedEgHatchFl
Sep 23, 2005 10:04 AM
