Turbo charging stock D16Z6
im in the process of getting a T3/T4 turbo charger and was wondering if i could run the system with a few pounds on a stock D16Z6 or do i need to do a little more work? it just a daily driver not trying to make it wild yet just testing the waters.
Re: Turbo charging stock D16Z6
can i turbo a stock d16z6 with stock compression if so how many pounds can i run safely before messing with compression and valves.
PHANTOM MENACE
I'm not a turbo expert, just wanted to say that first...
I understand that stock rods on these engines are generally good to 200ish HP so take that into consideration. Most important other than a hard number for lbs/boost or HP is your ability to make the engine "tunable." I'd address that before anything else.
GReddy's bolt on kit back in the day was based off of an otherwise stock engine but the turbo was fairly small.
then what info do you need to know. ive been reading other articles on turbocharging but was just asking if it would hurt the motor to turbo and run a few pounds with stock rods pistons compression or not.
POUNDS PER SQUARE INCH does not BREAK engine parts.
HORSEPOWER does.
So a better question would be how much horsepower will my d16z6 handle under boost.
And more info is needed to even give our .02.
Like mileage on enegine,compression test results, etc etc
HORSEPOWER does.
Can it be done? Yes. Goto the FAQ's section and do some browsing chapter 6. You'll be looking for this area here:
b. Forced Induction (Also see the Forced Induction subforum)
Turbocharging A Civic On A Budget
General Guide For Turbocharging Cars
Parts List For Assembling Turbo Kits
Installing A Turbo Kit On Your Civic
Building Your Own Oil Catch Can
Complete Guide To Installing A Drag 3 Turbo Kit
Mounting Oil Lines on Firewall
Nitrous System Basics Explained
You can easily get to this section via Grumblemarc's signature with the underlined part saying FAQ'S
im hench irl
Whatever you do dont cheap out on the tune, Go to a reputable tuner. This is the key to keeping the stock motor together.
Man U FTW
