B16a2 Swap/ Wiring Problem?
Old May 28, 2008 | 12:44 PM
HondaBoy4676's Avatar
Default B16a2 Swap/ Wiring Problem?
I have a 97 DX Coupe i just did a 2000 B16a2 Si Swap into. The swap came with everything wiring harness, n ecu. It all pluged in but when i drove it my gauge cluster dont work vtec dont engage and my raditor fan wont come on so it gets hott. Why is this? i was thinking cus its obd-2b n my chass is obd-2a but what can i do to fix this and can i drive it like that if i run a switch to my raditor fan to turn on for now?
Old Jun 3, 2008 | 01:51 PM
vtecb18c's Avatar
Default Re: B16a2 Swap/ Wiring Problem? (HondaBoy4676)
check all your fuses and all of your ground wired... maybe you got a bad ecu
Old Jun 3, 2008 | 02:42 PM
podjaski's Avatar
you might hAVE to rewire a couple pins also. i had a 97 cx with the same problem i hard wired the radiater fan with a fusable switch. and had to repin 3-4 wires on the ecu from the harness for the vtec to work took me about 5 hours to figure out
raiden571
Dec 11, 2007 10:03 AM
eghatchproject
14
Nov 3, 2003 04:40 AM
Ehron
Mar 4, 2003 05:06 PM
Ehron
Mar 2, 2003 04:00 PM
