Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
B20VTEC For Autocrossing?
Old Jul 15, 2002 | 10:37 PM
Db1 Supreme's Avatar
Default B20VTEC For Autocrossing?
Could the B20VTEC setup be used for autocrossing rather than going straight, or is the engine to heavy for autocrossing? Please let me know. Thanks!
Oh, And the car is a 92 civic hatch.
Old Jul 16, 2002 | 01:30 AM
JeffS's Avatar
Default Re: B20VTEC For Autocrossing? (EGSiX92)
Well, I'm sure you could have fun with it, but an engine swap would put you right up there with the best prepared cars out there...
...as long as you don't expect to win you'd be fine.
Old Jul 16, 2002 | 04:32 AM
MaddMatt's Avatar
Welcome to street mod, the domain of high horsepower turbo cars.
Although I am positive a light powerful hybrid can take them.
Old Jul 16, 2002 | 04:38 AM
Willard's Avatar
Default Re: B20VTEC For Autocrossing? (MaddMatt)
low end usable torque should work wonders.
Old Jul 16, 2002 | 05:32 AM
MaddMatt's Avatar
Default Re: B20VTEC For Autocrossing? (Willard)
That's what I'm talking 'bout
Old Jul 16, 2002 | 08:59 AM
Steve91's Avatar
A b20 would be a blast to autocross. I think a LSD will be essential. Spring rate selection will also be critical for a nose heavy car like that. Probably something on the order of 450# front 600# rear. Plus a big rear sway bar and no front sway bar.
Old Jul 16, 2002 | 09:12 AM
chad's Avatar
Moderator
Default Re: B20VTEC For Autocrossing? (Steve91)
i have auto crossed my b20vtec
second place 2 times in SM...lost both times to a friggin ruststang!!! by a tenth of a second!!!
my setup.
92 cx
rollcage
700 lb fronts
600 lb rears
bigbrakes
15 inch rims
i usually am in the top 10 times for the day.....
LSD also works nicely
that friggin stang has beaten me 2 times both on his last run!! by less than a tenth of a second both times!!! i'm bitter!!!
Old Jul 16, 2002 | 09:14 AM
Johnny Tran's Avatar
Default Re: B20VTEC For Autocrossing? (Chad)
chad, did you just admit defeat by a FORD product?
traN, who is in disbelief
Old Jul 16, 2002 | 09:15 AM
Reid's Avatar
Global Moderator
Interesting, Chad.
Any reason why you went with stiffer springs in the front than the rear?
Old Jul 16, 2002 | 09:43 AM
chad's Avatar
Moderator
Default Re: B20VTEC For Autocrossing? (Reid)
no reason....just did it that way....car is nice....gonna try the rear ITR bar then will see how the car handles
Old Jul 16, 2002 | 09:45 AM
Willard's Avatar
that is the reason the JDM vs USDM setup arguements suck...
install them, drive hard, and see if you like it.
[Modified by Willard, 1:45 PM 7/16/2002]
Old Jul 16, 2002 | 10:48 AM
Doctor CorteZ's Avatar
700 lb fronts
600 lb rears
SWITCH those springs AND get a real rear bar
14mm is for sissys
Old Jul 16, 2002 | 01:26 PM
acura_typer's Avatar
Banned
Default Re: B20VTEC For Autocrossing? (Doctor CorteZ)
baa...i can spin my 400/350 springs and I have GSR front, ITR rear bars.....
Old Jul 16, 2002 | 01:32 PM
Reid's Avatar
Global Moderator
Default Re: B20VTEC For Autocrossing? (acura_typer)
Spin your springs?
I'm lost.
Please clarify what you're trying to say.
Old Jul 16, 2002 | 01:36 PM
owen_the_soyboy's Avatar
sure thing it would plant you in SM but it would be so much fun to drive as well !
I just placed 17th overall out of 110 entrants, thats right, I was 3rd in SM out of 8 in that class, last weekend at a local SCCA autox.
GSR w/ LSD in a 92 CX
GC on Koni Yellow
rollbar, sparco seats, other goodies...
AND I dont even have my big brakes or swaybars on yet !
I got beat out by two DSMs... but I beat two others and a mean fox body Mustang V8 LX.
HAHAHA is the engine too heavy? NO its gotta be only 10-30 pounds heavier if at all over the other B series.. B18C/B18B/B16A, etc. You should go for it, the torque would rocket you out of corners.. plus that FAT power band would be so nice for the tougher courses. You cant go wrong with a lightweight chasis and a powerful motor.
Old Jul 17, 2002 | 04:55 AM
donkeypunch's Avatar
B16 is all you need in a hatch. I will rule D Mod by the end of the season.
DMod>SMod
Although the B20 bottom end would keep me from shifting all the time.
punch
Old Jul 17, 2002 | 05:24 AM
solo-x's Avatar
Default Re: B20VTEC For Autocrossing? (donkeypunch)
heavier springs AND a big swaybar up front make sense. the old school setup was soft front springs with really stiff rear springs and no front bar with a big rear bar. to me this doesn't make sense with the newer shock technology. i have my stiffer springs on the front with itr sway bar's front and rear. the car has massive amounts of grip and NO push. i had to increase rear toe-in to tame the rear end. as long as you go with a stiff enough spring to balance out the stiffer sway bar and use a good enough shock to control the spring you should be all set.
BbqEazyE
Aug 25, 2008 06:24 AM
92Slivic
Feb 5, 2008 08:48 PM
redexchris
Apr 7, 2003 11:37 PM
Mojo-Jojo
Oct 14, 2002 11:08 AM
Prelussion
Jan 29, 2002 05:40 PM
