JDM vs USDM ECU - wiring problems
Old May 28, 2008 | 08:39 AM
jksmith's Avatar
Default JDM vs USDM ECU - wiring problems
I have some sort of wiring issue: here is what is happening
running LS/Vtec w/ obd2-obd1 jumper
with virgin JDM P72 OBD1 ecu hooked up it runs fine just pulls knock sensor light every once in awhile
with 2 different USDM P28 obd1 ( 1 chipped on was not) they both immediately started smoking - literally started smoking,
anyone have any ideas?????
Old May 28, 2008 | 10:01 AM
jksmith's Avatar
bump
Old May 28, 2008 | 10:39 AM
Jim Truett's Avatar
Default Re: (jksmith)
You have the connectors for the EVAP purge solenoid and IAT sensor swapped. You now most likely have a melted IAT sensor as well as two P28 ECUs with Q31 fried.
Old May 28, 2008 | 11:45 AM
jksmith's Avatar
is there a simple easy cheap fix??? i dont want to buy a new engine harness....
Old May 28, 2008 | 04:10 PM
jksmith's Avatar
bump!!
zammitjon
Aug 24, 2009 08:58 PM
jksmith
May 31, 2008 09:11 AM
jksmith
May 30, 2008 10:13 AM
SupaFly_Honda
Jun 1, 2005 06:15 AM
winman517
Mar 9, 2005 08:24 PM
