car cut out and wont start
Old May 28, 2008 | 03:34 AM
irishboy's Avatar
Default car cut out and wont start
hi guys im from ireland i have a 95 eg coupe with dc2 typer engine in it, was drivind along and the engine check came on so turned car off and back on and the car just died as if ran out of petrol. got car back to house did ecu flase and got code 41, found the problem it being broken wire in dizzy fixed it but car still ait startin have good comp,full spark and loads of fuel any ideas!!!!????????
Old May 28, 2008 | 07:58 AM
ambryatim's Avatar
Verify the timing. And check to see if #1 is at TDC.
Old May 28, 2008 | 08:12 AM
irishboy's Avatar
Default Re: (ambryatim)
have checked the timing and its perfect, no blown fuses or relays dunno what to be looking for
Old May 28, 2008 | 08:58 AM
cashkeith's Avatar
Default Re: (irishboy)
is it cranking out geting spark
Old May 28, 2008 | 09:24 AM
ambryatim's Avatar
Did the CEL go away afer you made the repair? Did you reset the ECU? The CEL should come on with the fuel pump cycle when the key is in the "run" position and after the pump shuts off, so should the CEL if not you might still have a problem.
jtjtjt
22
Feb 17, 2012 02:46 PM
CivCruise
12
Jul 11, 2009 09:27 AM
DA_9
Mar 11, 2008 03:17 PM
Siegfried
Nov 19, 2006 04:35 PM
BOOSTEDgreeneg
Sep 15, 2005 07:27 PM
