who is using the greddy profec b spec II
Old May 27, 2008 | 06:16 PM
syclone50's Avatar
Default who is using the greddy profec b spec II
I am having trouble with getting my greddy to control boost and think I have it hooked up wrong. Would someone be so kind as to tell me where each and every vacuum line is hooked up. Where the lines from the wastegate to the solenoid go and which side. and then where you tapped in for the controller box inside the car.
Thanks!!!
Old May 27, 2008 | 10:45 PM
B20EF's Avatar
Default Re: who is using the greddy profec b spec II (syclone50)
http://www.greddy.com/img/PHP/products/pdf/689.pdf
I haven't installed mine yet, but hopefully this helps you.
Old May 28, 2008 | 07:01 PM
syclone50's Avatar
Thanks, but I have the instructions and installed it they way they suggest but cannot get it to work.
Old May 28, 2008 | 09:08 PM
dpetro1's Avatar
Default Re: (syclone50)
what settings are you using? and again, are you positive you have it installed correctly? is the car just over boosting in general or is it creeping or spiking at all?
dcmodnight
Aug 2, 2011 09:44 PM
MAFDARK
Jun 4, 2007 11:24 AM
wutupnut
Jun 2, 2005 03:13 AM
uneekcrx
May 27, 2002 03:48 PM
