Classic Hondas All Pre-1988 Hondas.
How do you adjust idle on carb?
Old May 27, 2008 | 05:01 PM
86gasaver1500's Avatar
Default How do you adjust idle on carb?
Just picked up my 1st carbureted vehicle, and I have no idea how to set the idle on the carb.
It's an 86 civic. 1.3L 4spd. No tach, so I dont know where the idle is, but it sounds like its idling at 3K-4K rpms.
Some help please?
Old May 28, 2008 | 04:48 AM
MSchu's Avatar
My Name is Nobody
Default Re: How do you adjust idle on carb? (86gasaver1500)
there should be a air/fuel ration screw on the body of the carb somewhere... also make sure you have some MINOR play in the cable when its fully relaxed, if the cable is to tight you may be pulling on the butterfly slightly causing a fast idle
Old May 28, 2008 | 06:42 AM
Default Re: How do you adjust idle on carb? (MSchu)
any idea where this is? I dont want to adjust the wrong thing!
pictures? please? This thing runs well, just idles VERY high. I know the carburetor was messed with at some point, so I think the idle just needs to be adjusted, and she can be driven.
Old May 28, 2008 | 07:03 AM
MSchu's Avatar
My Name is Nobody
there are so many different variants... post a picture of your carb
Old May 28, 2008 | 08:01 AM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
Since no one has said it yet, http://www.redpepperracing.com/forums/index.php? is the best place in the world for info on your vehicle.
From the manual at the top of every page go to the carbureted section and read the pages on the automatic choke, fast idle unloader, and choke opener. You need to make sure that the choke is opening and that the fast idle cam is unloading to let your idle fall down to where it is set with the idle screw. Be sure to check all of your vacuum lines for leaks. Once that is done, you can inspect and adjust the idle mixture and idle speed as described on pages 11-24 to 11-27. If you have done all that and still have a problem then post your questions in the Technical-->Carbs forum. Good luck!
Old Jun 4, 2008 | 05:54 AM
TurbodTegSfaria's Avatar
Default Re: How do you adjust idle on carb? (tjbizzo)
also check for vacuum leaks within..
Old Jul 8, 2021 | 04:54 PM
Shakason's Avatar
I have an 86 honda sedan, it has a 3bbl keihin carb on it and yesterday I went to drive it around and it died at the red light. I pulled into a parking lot to adjust the primary idle adjust screw on the back of the carb next to the coolant hose. It wasn’t there, at some point it fell out, I’m trying to find an aftermarket one online or get one off of another carb but designs are different and I need some help, some guidance from fellow shitbox owners. No offense, I take pride in keeping my shitbox living.
Old Jul 22, 2021 | 10:48 AM
letank's Avatar
junkyards are you best bet.... 84 to 87 are the same generation for carbs
here on the left coast we have picknpull dot com which has a online inventory check
Arthas
Mar 14, 2010 09:08 PM
SAfire
Jan 25, 2009 11:51 PM
94typeR
Mar 28, 2007 05:49 AM
PINKS
May 29, 2006 10:26 PM
djtech
Mar 30, 2003 04:51 PM
