H22A4 PROBLEMSSSS.!!!!! HELP....
i have a 93 del sol swap h22a4 i have a stock fuel pump!! but the car it does not give in 3rd gear you think need the fuel pump like a walbro?
look my car have skunk2 intake manifold,lsd tranny,clutch xtd stage3 flywheel xtd headers dc sport, but the car feel so good in 1st and 2nd gear but in 3rd gear the car does't give power, other thing my del sol has the stock exhaust you think that can be the problem???????
it doesnt help. take the exhaust off and see what happens.
you arent telling us anything to be able to help you.
compression test?
cam timing?
ignition timing?
dyno chart?
what ecu?
tuning?
maintenance?
compression test?
cam timing?
ignition timing?
dyno chart?
what ecu?
tuning?
maintenance?
i living in mexico my friend jejje the dyno no exist here
a friend said to me that it was gasoline problem, for that reason I make the commentary to expert people here my del sol has a stock fuel pump i don't need to change for other like a walbro???
DarkGriffin3156
11
Nov 21, 2021 05:33 PM
i will check the clutch!! but it is not slid, only that the leg of clutch this very down
