p75 head on b16a2 ?
Old May 25, 2008 | 09:39 PM
importwarriorsi's Avatar
Default p75 head on b16a2 ?
Will a p75 head work on the b16a2 block thanks.
Old May 25, 2008 | 09:44 PM
vtecb18c's Avatar
Default Re: p75 head on b16a2 ? (importwarriorsi)
you cant put an ls/b20 head on a vtec block
Old May 26, 2008 | 12:19 AM
Hspec's Avatar
Default Re: p75 head on b16a2 ? (vtecb18c)
WHY WOULD YOU WANT TO DO SUCH A THING?
Old May 26, 2008 | 08:18 AM
superfast666's Avatar
Default Re: p75 head on b16a2 ? (Hspec)
vtecb18c is wrong you can but there is no point
Old May 27, 2008 | 04:11 PM
ekgcool's Avatar
Default Re: p75 head on b16a2 ? (superfast666)
What if the point is to "put something together" for CHEAP! Power may be near D16Z output but truly how much would it set you back. I have a stock pile of non-vtec heads and b16 short blocks. When my LS-V takes a poop guess whats waiting...
Old May 27, 2008 | 10:04 PM
drSquish's Avatar
correct me if I'm wrong, but all you theoretically have to do is plug the VTEC oil orifices, get the nonvtec pulleys (crank, cam gears, and proper belts), the right head gasket, and tune it
...with balanced internals you would be able to redline much higher than a nonvtec motor, but it probably wouldn't be worth it with that head
Modified by drSquish at 2:14 AM 5/28/2008
Old May 28, 2008 | 03:22 AM
gibsanez's Avatar
Default Re: (drSquish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekgcool &raquo;</TD></TR><TR><TD CLASS="quote">What if the point is to "put something together" for CHEAP! Power may be near D16Z output but truly how much would it set you back.</TD></TR></TABLE>
I'm sorry but i'd rather not drive my car than have something with D series power in it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drSquish &raquo;</TD></TR><TR><TD CLASS="quote">correct me if I'm wrong, but all you theoretically have to do is plug the VTEC oil orifices, get the nonvtec pulleys (crank, cam gears, and proper belts), the right head gasket, and tune it
What timing belt would you even use? A lot of this build has always been speculation because no one has ever bothered to try it.
Old May 28, 2008 | 04:48 AM
drSquish's Avatar
Gibsanez you miss the point. Why do people drive D16s in the first place.....hmmmm they are gas savers and cheap!!! If you have the parts laying around why not use them? Now that I think about it, you'd have to go with B16 pulleys because the deck height on that block will only work with a b16a belt.
packman5280
Dec 27, 2007 08:09 AM
02RSXS
Jan 25, 2005 02:17 PM
Drastic Mezures
Apr 6, 2004 04:23 PM
tmekjian
Apr 22, 2003 12:30 PM
Si
Feb 3, 2003 05:20 PM
