B16A2 head on B18 block...
Old Feb 3, 2003 | 03:19 PM
Si's Avatar
Si
Default B16A2 head on B18 block...
I was planning on getting a GSR swap but I was told that the B16A2 head would go on the B18 block, is that true? So if I can then I'll just buy a GSR short block and put the b16 head on that. Would that be a good combo? Thanks
Old Feb 3, 2003 | 03:26 PM
fire7882's Avatar
Default Re: B16A2 head on B18 block... (RedSi99)
it will work and some say that the b16 head is better but we will not get into all that.
Old Feb 3, 2003 | 03:29 PM
Si's Avatar
Si
Default Re: B16A2 head on B18 block... (fire7882)
Cool. Thanx
Old Feb 3, 2003 | 03:31 PM
joe_bocc's Avatar
you've discovered what is know as the LS/VTEC. A very common setup. you could also look into a CRVTEC which a B20 block with the VTEC head on it. really good for all motor.
Old Feb 3, 2003 | 05:20 PM
b19coupe's Avatar
Default Re: B16A2 head on B18 block... (joe_bocc)
You need to reread the original post, he is talking about a GSR shortblock. B16 head on a GSR is a VTEC/VTEC. And a B16 head is a good head, same casting as the ITR head, should work fine. Get a little P & P on the B16 head and you will really be happy.
carbonn
Jun 9, 2009 12:58 PM
NJz HondaBoi
Apr 30, 2009 10:19 AM
guinnessstout
Jan 21, 2009 12:09 AM
BlakeJ53
Dec 28, 2006 01:34 PM
SpoonEk253
Apr 14, 2006 04:35 PM
