Can this be Repaired ???
Old Jul 15, 2002 | 06:36 PM
webhitch's Avatar
Default Can this be Repaired ???
Just wondering if this can be repaired or if i should start looking for a new Block.. Any input would be cool the more detail the better. First hand knowledge would be a big help.
Thanks
Old Jul 15, 2002 | 06:46 PM
AlphaKennyWun's Avatar
Default Re: Can this be Repaired ??? (webhitch)
Give it to me I could always use another block....
But actually its nothign a good welder couldnt cut and refabricate...
I think
[Modified by SO3Burner, 3:46 AM 7/16/2002]
Old Jul 15, 2002 | 07:08 PM
martini's Avatar
Default Re: Can this be Repaired ??? (SO3Burner)
it would take a very good welder with a very good welding machine.
I had the same thing on my JDM B16A. Must've been a left frontal or left fender impact.
http://www.fatboyraceworks.com/crx/i...6/DSCF0016.jpg
http://www.fatboyraceworks.com/crx/i...6/DSCF0018.jpg
Sorry for the blurry picture.
I said "**** it" and bought a B18B for the LS/VTEC.
Since then, I've considered taking it down to the local tech school and having them take a crack at it as a learning project. I'm sure the instructor wouldn't let them **** it up too much, and I would get a finished project back for free.
[Modified by martini, 8:09 PM 7/15/2002]
Old Jul 16, 2002 | 01:00 AM
Kamin's Avatar
is the attachment for the crank pulley bent too?
if that is, i say scrap the bottom end and slap a b20 under that head.
Old Jul 16, 2002 | 02:50 AM
tinkerbell's Avatar
Default Re: Can this be Repaired ??? (KAMiN)
i bet you'd say that to most!!!
JK!
seriously, how cheap is a B16A block over there?
would it cost more to weld it properly or what?
have the block crack tested etc, man the whole block could be screwed...
t..
Old Jul 16, 2002 | 05:37 AM
Speed PHreak's Avatar
Default Re: Can this be Repaired ??? (tinkerbell)
JB Weld! Whats the worst that could happen?
Old Jul 16, 2002 | 08:23 AM
B20T's Avatar
I agree with speed jb weld it ... me and my buddy did it and it works fine ,but his was broken worse there were 1 hole left so we jb weld the bracket to the block. it hold just fine..
B20t vtec 360hp@10psi pump gas
Old Jul 16, 2002 | 08:45 AM
webhitch's Avatar
Default Re: Can this be Repaired ??? (B20T)
Thanks for all your Input guys... The guy i bought the swap from is going to give me a different block or give me back a few $$ so i can find a good one. I'm kinda hoping he will give me some $$ back so i can find a B20 block we will see. i'll keep you posted.
Keep the info coming in if you have some first hand knowledge the more the better...
Thanks again it has been a big help..
BTW-- the Crank is fine the pully took no hit. The exhuast mani was hit and pushed the hole engine back from there. One Exhuast Mani Stud was broken but that is no big deal.
Later
[Modified by webhitch, 5:45 PM 7/16/2002]
[Modified by webhitch, 5:46 PM 7/16/2002]
Old Jul 18, 2002 | 12:52 AM
quickspoolin's Avatar
My cousin bought a car with the motor just like that. Nothing that a good a aluminum welder couldn't fix.
Old Jul 18, 2002 | 07:56 AM
IlikeTODA's Avatar
Default Re: Can this be Repaired ??? (Speed PHreak)
I like how this guy thinks.
You can get that repaired, but I dont know what your going to do about the bent dipstick.
Thanks, J
EGhachiback
Jun 4, 2015 01:46 AM
ACrite3404
May 20, 2008 11:52 AM
ACrite3404
Apr 20, 2008 07:31 AM
ACrite3404
eddie1681
May 6, 2003 12:52 PM
