block gaurd? good or bad?
Old Nov 6, 2001 | 02:04 PM
eddie1681's Avatar
New User
Default block gaurd? good or bad?
Hi
I have a B16a I will turbocharge it soon, what do you guys think about the block gaurds?
I have heard of good and bad things, like over heat and such.
Does it matter what brand or should I get the nuformz?
One last thing any info on copper head gaskets? Is it better then stock?
Thanks
Old May 4, 2003 | 07:49 PM
TORQUE MONSTER's Avatar
Default Re: block gaurd? good or bad? (b20z)
bump i'd llike to know
Old May 4, 2003 | 07:50 PM
Broken Gearbox's Avatar
Default Re: block gaurd? good or bad? (TORQUE MONSTER)
like to know too...also do you just put the block guard in without any modifications?
Old May 4, 2003 | 09:28 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Here, there should be good information within both these threads:
https://honda-tech.com/zerothread?id=484630
https://honda-tech.com/zerothread?id=412298
Old May 4, 2003 | 09:37 PM
Trial User's Avatar
Default Re: block gaurd? good or bad? (INVALID)
This might change your mind... https://honda-tech.com/zerothread?id=485070
Old May 4, 2003 | 09:40 PM
BOOSTED 4DR. GS-R's Avatar
Default Re: block gaurd? good or bad? (Trial User)
block guard is a fine. I have used one for two years no problems. no overheating.
Mine is race engineering.
Old May 4, 2003 | 10:35 PM
V-SPEC 1's Avatar
Default Re: block gaurd? good or bad? (BOOSTED 4DR. GS-R)
Here's some pics of my friend's LS turbo that I'm building. It's Golden Eagle block guard.
http://www.we-todd-did-racing....3D%3D
Old May 4, 2003 | 10:40 PM
Default Re: block gaurd? good or bad? (boostedb20vtec)
nice pictures...how hard was it to install??...how long did it take you and what did u have to do?
EDIT: also when is it nessecsary to install one??
-iLLuZioN-B18C1's Avatar
blockguards are only bad if you dont do it right!
Old May 4, 2003 | 10:50 PM
V-SPEC 1's Avatar
Default Re: block gaurd? good or bad? (Powered By D15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Powered By D15 &raquo;</TD></TR><TR><TD CLASS="quote">nice pictures...how hard was it to install??...how long did it take you and what did u have to do?
EDIT: also when is it nessecsary to install one??</TD></TR></TABLE>
It only took me no more than 10 min. maybe less. It's not hard at all. All you have to do is line the BG to the hole and make sure the chamfered side facing down and tap it light with a rubber mallet down pass the flush of the deck a little bit. If you have to force it in there, don't do it, take it off and shave the area that is tight with a file and try it again until it slide right in quite easy.
Old May 4, 2003 | 10:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedb20vtec &raquo;</TD></TR><TR><TD CLASS="quote">
It only took me no more than 10 min. maybe less. It's not hard at all. All you have to do is line the BG to the hole and make sure the chamfered side facing down and tap it light with a rubber mallet down pass the flush of the deck a little bit. If you have to force it in there, don't do it, take it off and shave the area that is tight with a file and try it again until it slide right in quite easy.</TD></TR></TABLE>
isnt this bad? from what ive heard you need to weld it in, bore and hone to make sure that it doesnt warp the cylinders in the future (like turning egg shaped)
Old May 4, 2003 | 11:02 PM
V-SPEC 1's Avatar
Default Re: block gaurd? good or bad? (jvithayapun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jvithayapun &raquo;</TD></TR><TR><TD CLASS="quote">
isnt this bad? from what ive heard you need to weld it in, bore and hone to make sure that it doesnt warp the cylinders in the future (like turning egg shaped)</TD></TR></TABLE>
It's perfectly safe. After I installed the BG, I took the motor to the shop and have them check for roundness of the cylinder and it turn out that #1,#2 & # 4 are zero. Meaning its perfectly round. and #3 is .0005 off.
Old May 5, 2003 | 01:08 PM
It's perfectly safe. After I installed the BG, I took the motor to the shop and have them check for roundness of the cylinder and it turn out that #1,#2 & # 4 are zero. Meaning its perfectly round. and #3 is .0005 off.</TD></TR></TABLE>
how bout after driving it around and all that, wont that affect the cylinder shape after a while?
Old May 5, 2003 | 09:33 PM
V-SPEC 1's Avatar
how bout after driving it around and all that, wont that affect the cylinder shape after a while?</TD></TR></TABLE>
I highly doubt it. Look at those people that are using it, the majority of them have no problem at all.
Vic
Old May 5, 2003 | 09:55 PM
ion_four's Avatar
I think that if it's rather loose (like a couple thousandths of an inch) that would be the safest, allowing a little bit of expansion...even if you only have to tap it in, it would seem that the sleeves would expand enough to apply a lot of pressure where the sleeve is.
It seems that Sonny and Bryson have or will brace their blocks with with some studs about 2/3 of the way up the sleeves...does anyone know if this will pose a problem with expansion of the sleeve and having such a small contact area?
I can't afford to get my block sleeved, so I think I am going to stud it and POUND in a block gaurd sound like a good plan?
Old May 6, 2003 | 12:52 PM
g2turbo's Avatar
Default Re: block gaurd? good or bad? (ion_four)
i would say no but ive seen bad experiences with blockguards. But it may have been the install. Basically if you have to cram the blockgurad in the coolant passages to get it to fit then when the engine goes through a few heat cycles it may egg-shape the cylinders. Just something to think about. also i have seen many dyno graphs on stock sleeves that made well over 300whp so why mess with a good thing. detonation kills motors not necessarily just the boost level.
katoeh2o
Apr 21, 2008 10:05 PM
MidShipCivic
Welding / Fabrication
Feb 28, 2006 11:18 PM
4doorH22
Mar 9, 2003 01:26 AM
b18cTurbo
Dec 11, 2001 03:40 PM
