how do you check for a bent shift fork
Old Jul 15, 2002 | 06:32 PM
gsr98vtec's Avatar
Default how do you check for a bent shift fork
like the title says, any help appreciated. thanks guys
Old Jul 15, 2002 | 09:13 PM
stevel's Avatar
Default Re: how do you check for a bent shift fork (gsr98vtec)
go under the car and look at the shift fork. that's the easiest. it's right there going from the tranny to the shifter.
s
Old Jul 15, 2002 | 09:23 PM
fredren's Avatar
Default Re: how do you check for a bent shift fork (stevel)
I think he means the shift fork inside the transmission.
Old Jul 15, 2002 | 10:04 PM
Pengo's Avatar
Default Re: how do you check for a bent shift fork (fredren)
yea, he prob means in tranny. u'll hafta open up ur tranny to get to the insides
Old Jul 16, 2002 | 03:36 AM
Mista Bone's Avatar
D Tranny Guru
you don't............
You have to drop out the tranny, then split it apart. While sitting there with tranny inyards about, replace the shifter forks if you question them!!!!!
On SOHC trannys I usually have 1 1-2 fork on hand because theys always need replaced.
I've broke 3 myself.
LSVTECEG757
16
Mar 20, 2007 06:55 PM
davidluko
Mar 9, 2007 03:59 AM
red_crx
Oct 3, 2005 01:57 PM
hatchback
Jan 4, 2003 11:08 PM
