V-tec problem *searched this is new i think*help!!!
Old May 24, 2008 | 10:26 PM
civicking99's Avatar
Default need expert help with a vtec problem *searched*
I have a jdm b16a in a 1998 honda civic. It has itr cams and is being ran on an itr ecu. What is happening is my v-tec kicks on fine and hits. Then my car sounds like it has a really wierd miss or just like a subaru. But it carriers over after vtec into normal rpms. Then it will go away and sound normal after you stop at a light or just drive it under vtec for a min. Car runs good and strong but when vtec hits the weird miss sound comes. But does not affect vtec power at all. You can only really start to here it after you shift or get below vtec. (lower rpms)
(almost sounds out of time. then goes away)
I have tried
1.I already tried a different ecu (p30) still the same thing
ANY INPUT WOULD HELP PLESE
Modified by civicking99 at 8:00 PM 5/26/2008
Old May 25, 2008 | 08:23 AM
dj theoretic's Avatar
Confusing question, but I think I got it. Other than your Vtec not hitting at 5500 rpm or the solenoid being broken, I think it's fine. Check your exhaust it might have a leak or something......????
Old May 25, 2008 | 02:48 PM
sorry posted that late last night half asleep i revised it, but my vtec is hitting. Its not the exhaust because my car sounds normal before i go into vtec and if i wait after i just am wondering whats making it do that
Modified by civicking99 at 4:28 PM 5/25/2008
Old May 25, 2008 | 06:03 PM
GarethHatch's Avatar
Well, on a subaru, the noise is caused by un-equal length headers
So, do you have an aftermarket exhaust manifold? (an ebay one specifically as they're a bit poor in the quality department)
If you havn't, no idea sorry!
Gareth
Old May 26, 2008 | 05:15 PM
have dc headers so should have at least decent quality. But it like start missing or something not just noise
Old May 26, 2008 | 07:00 PM
love4dirt's Avatar
Default Re: !!!V-tec problem *searched this is new i think*help!!! (civicking99)
is it just a noise or is there any powerloss that comes along with it? also did it throw any check engine codes? you should also tell us what year and motor you have.
Old May 26, 2008 | 07:04 PM
the post explains engine
just
o2 circuit heater
Old May 26, 2008 | 07:10 PM
love4dirt's Avatar
Default Re: need expert help with a vtec problem *searched* (civicking99)
i swear that changed after i posted it or im on drugs that i didnt know of... anyway, i know someone that changed out their injectors with out tuning it for em and id did a similar thing, i dont know what code the the ecu showed for that though... did you change anything on your car for this to happen or is it a new and abrupt thing?
Old May 26, 2008 | 08:00 PM
it happened after the cams, but not right away so im not sure if that has anything to do with it.
The story is i have my friend bought a jdm b16 long block and then built a gsr bottom. So i bought his jdm b16 bottom end and put my head with new cams valspring and retainers and new ecu. all itr but its directly corrilated with vtec its happening only when i hit it not before
malo11
21
Dec 24, 2022 04:57 PM
Danielsb20crx
24
Jul 5, 2009 01:37 AM
squeeks
11
Mar 8, 2008 04:49 PM
91EF_Si
20
Sep 17, 2007 12:00 PM
Wave
Aug 1, 2003 06:04 PM
