I payed more than $200 for nothing
Old May 24, 2008 | 08:29 PM
carlirus's Avatar
Default I payed more than $200 for nothing
I have a 94 Accord LX ,2 dr, 4 cyl, after drive for a while,the car just turn off by it self, and the check light comes up, then, I wait about 3 min, and I turning on, and works fine, I brought it to the mecanic, conected the computer, checked battery, Coil, distribuitor, switch, even, removed old alarm brain from the ignition switch, On the computer nothing is wrong, I don know what to do, when I left the shop, abot 20 min later, the car stops running AGAIN!..........
Anybody have an idea about it, Please
Old May 24, 2008 | 08:41 PM
chopper68's Avatar
Default Re: I payed more than $200 for nothing (carlirus)
Does it just die or does it stumble and then die? like maybe its not gettin fuel, or spark.
Old May 24, 2008 | 08:46 PM
carlirus's Avatar
Default Re: I payed more than $200 for nothing (chopper68)
The car just Die, then I turn the shitch off, then after 2 or 3 min, I turn on and start normal!!
Old May 24, 2008 | 09:36 PM
BLKFLSH's Avatar
I have two guesses. Ignition switch and fuel pump relay.
Old May 25, 2008 | 12:33 AM
Civic_4life's Avatar
happen to my civic liek that but im not 100% sure but i found out that my ecu is burn, and my dizzy is totally fried.. and my manifold is really dirty so not much air can get in it, so check sensors on intake mani and clean out iacv w/e its called and jsut try it mgiht help
Old May 25, 2008 | 07:37 AM
TheMuffinMan's Avatar
He knows where you live!
Default Re: I payed more than $200 for nothing (BLKFLSH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLKFLSH &raquo;</TD></TR><TR><TD CLASS="quote">I have two guesses. Ignition switch and fuel pump relay.</TD></TR></TABLE>
x2 on Ignition Switch (electrical portion)
Old May 25, 2008 | 08:23 AM
i93SE's Avatar
no it main relay
causes Ignition switch and fuel pump relay many other ****
Old May 25, 2008 | 09:37 AM
hondadude's Avatar
x3 on Ignition Switch (electrical portion)
Word of WARNING If you have air bags and go to change the electrical part of the ignition switch be very <U>CAREFUL</U> around the ribbon cable that attaches the SRS unit. The connectors are easy to disturb.
Old May 25, 2008 | 01:37 PM
EuroKing99's Avatar
Default Re: I payed more than $200 for nothing (hondadude)
i would say main relay since my car did the same **** whenever it felt like. it hasnt happened since i installed a new main relay
Old May 25, 2008 | 02:17 PM
johnlear's Avatar
Banned
My bet is the 'ignitor' which is a module that lives inside the distributor. Your symptoms are very similar to what my car had when my ignitor was on the way out. Ignitors are killed by old age, and also by high resistance in the HT leads, so get those checked.
Old Jun 6, 2008 | 03:55 AM
Losiracer2's Avatar
Default Re: I payed more than $200 for nothing (johnlear)
its the ignitor unit in the distributor, Chances are oil is leaking into there and it fried it.
Old Jun 6, 2008 | 09:12 AM
NeKe1point0's Avatar
Default Re: I payed more than $200 for nothing (Losiracer2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLKFLSH &raquo;</TD></TR><TR><TD CLASS="quote"> Ignition switch </TD></TR></TABLE>
x4
Old Jun 6, 2008 | 09:58 AM
SofireGuy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">x3 on Ignition Switch (electrical portion)
Word of WARNING If you have air bags and go to change the electrical part of the ignition switch be very <U>CAREFUL</U> around the ribbon cable that attaches the SRS unit. The connectors are easy to disturb.</TD></TR></TABLE>
Hahaha... that would suck if you were working on the ignition switch and then *BOOM* you got knocked out by the dang airbags.. *ouch*
jacobsd1904
Feb 24, 2011 01:18 PM
slammed em1
Apr 20, 2010 01:23 AM
superhatchbackbros
Mar 2, 2010 03:05 PM
GiMpInThaCiv
Apr 27, 2006 09:07 AM
Honda Virgin
Jun 2, 2004 12:34 PM
