I payed more than $200 for nothing
Old 05-24-2008, 08:29 PM
carlirus's Avatar
Default I payed more than $200 for nothing
I have a 94 Accord LX ,2 dr, 4 cyl, after drive for a while,the car just turn off by it self, and the check light comes up, then, I wait about 3 min, and I turning on, and works fine, I brought it to the mecanic, conected the computer, checked battery, Coil, distribuitor, switch, even, removed old alarm brain from the ignition switch, On the computer nothing is wrong, I don know what to do, when I left the shop, abot 20 min later, the car stops running AGAIN!..........
Anybody have an idea about it, Please
Old 05-24-2008, 08:41 PM
chopper68's Avatar
Default Re: I payed more than $200 for nothing (carlirus)
Does it just die or does it stumble and then die? like maybe its not gettin fuel, or spark.
Old 05-24-2008, 08:46 PM
carlirus's Avatar
Default Re: I payed more than $200 for nothing (chopper68)
The car just Die, then I turn the shitch off, then after 2 or 3 min, I turn on and start normal!!
Old 05-24-2008, 09:36 PM
BLKFLSH's Avatar
I have two guesses. Ignition switch and fuel pump relay.
Old 05-25-2008, 12:33 AM
Civic_4life's Avatar
happen to my civic liek that but im not 100% sure but i found out that my ecu is burn, and my dizzy is totally fried.. and my manifold is really dirty so not much air can get in it, so check sensors on intake mani and clean out iacv w/e its called and jsut try it mgiht help
Old 05-25-2008, 07:37 AM
He knows where you live!
TheMuffinMan's Avatar
Default Re: I payed more than $200 for nothing (BLKFLSH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLKFLSH &raquo;</TD></TR><TR><TD CLASS="quote">I have two guesses. Ignition switch and fuel pump relay.</TD></TR></TABLE>
x2 on Ignition Switch (electrical portion)
Old 05-25-2008, 08:23 AM
i93SE's Avatar
no it main relay
causes Ignition switch and fuel pump relay many other ****
Old 05-25-2008, 09:37 AM
hondadude's Avatar
x3 on Ignition Switch (electrical portion)
Word of WARNING If you have air bags and go to change the electrical part of the ignition switch be very <U>CAREFUL</U> around the ribbon cable that attaches the SRS unit. The connectors are easy to disturb.
Old 05-25-2008, 01:37 PM
EuroKing99's Avatar
Default Re: I payed more than $200 for nothing (hondadude)
i would say main relay since my car did the same **** whenever it felt like. it hasnt happened since i installed a new main relay
Old 05-25-2008, 02:17 PM
Banned
johnlear's Avatar
My bet is the 'ignitor' which is a module that lives inside the distributor. Your symptoms are very similar to what my car had when my ignitor was on the way out. Ignitors are killed by old age, and also by high resistance in the HT leads, so get those checked.
Old 06-06-2008, 03:55 AM
Losiracer2's Avatar
Default Re: I payed more than $200 for nothing (johnlear)
its the ignitor unit in the distributor, Chances are oil is leaking into there and it fried it.
Old 06-06-2008, 09:12 AM
NeKe1point0's Avatar
Default Re: I payed more than $200 for nothing (Losiracer2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLKFLSH &raquo;</TD></TR><TR><TD CLASS="quote"> Ignition switch </TD></TR></TABLE>
x4
Old 06-06-2008, 09:58 AM
SofireGuy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">x3 on Ignition Switch (electrical portion)
Word of WARNING If you have air bags and go to change the electrical part of the ignition switch be very <U>CAREFUL</U> around the ribbon cable that attaches the SRS unit. The connectors are easy to disturb.</TD></TR></TABLE>
Hahaha... that would suck if you were working on the ignition switch and then *BOOM* you got knocked out by the dang airbags.. *ouch*
jacobsd1904
02-24-2011 01:18 PM
slammed em1
04-20-2010 01:23 AM
superhatchbackbros
03-02-2010 03:05 PM
GiMpInThaCiv
04-27-2006 09:07 AM
Honda Virgin
06-02-2004 12:34 PM
Quick Reply: I payed more than $200 for nothing
