Header and Exhaust Temperature questions.
Old May 23, 2008 | 08:29 AM
TheOdd001's Avatar
Default Header and Exhaust Temperature questions.
So I got an new infrared thermometer and was taking some readings on my normal operating temperature idling prelude on it's header and observed this:
It seemed like #2 cylinder was always 100F greater than the rest... Does this indicate a problem?
Also, I once had to replace my cat because the inside was melted due to my timing being way off and replaced it with a high flow cat. I took some readings on the down pipe and on the cat. From the header on down I got lowering temps until I got to the cat, heres a picture of the temps I was getting:
Is this little increase normal?
Old May 23, 2008 | 10:07 AM
Jim Truett's Avatar
Default Re: Header and Exhaust Temperature questions. (TheOdd001)
Cat looks normal. Swap #2 and #4 injectors and see if #4 runs hot. If so, replace the injector.
Old May 23, 2008 | 04:50 PM
Dogginator's Avatar
Daisy... Daisy...
Knock the rust off of the surface before taking the reading. The rust can affect both the conduction and emmisivity of the surface.
bOOsTiNSoHcVtEc
Jun 24, 2004 08:41 PM
GothicTuner
Mar 26, 2003 12:41 PM
GothicTuner
Mar 26, 2003 11:51 AM
HatchBox
15
Jul 21, 2002 05:37 PM
citanest
Jul 19, 2001 12:41 PM
