HELP! im using an ecu from an automatic in a manuel?
Old May 22, 2008 | 07:06 PM
tealsvteceg's Avatar
Default HELP! im using an ecu from an automatic in a manuel?
im trying to use an automatic transmission p06 for my manuel ls vtec swap. do i need to do something to the ecu so make it a manuel ecu or what? HELP!
Old May 23, 2008 | 11:51 AM
93egboosted's Avatar
Default Re: HELP! im using an ecu from an automatic in a manuel? (tealsvteceg)
you do need a manual ecu and a manual engine harness
Old May 23, 2008 | 05:34 PM
GhostAccord's Avatar
Default Re: HELP! im using an ecu from an automatic in a manuel? (93egboosted)
You can convert your auto P06 to manual. I do them all the time. As for the rest of your swap as long as you followed a good Auto to manual swap thread. I'm not 100% on what harness you guys use to do the swaps. Seems like swapping a full harness just to get rid of a few ATM/ TCU & ECU wires would be a lot of work.
Are you familiar with soldering?
Modified by GhostAccord at 10:46 PM 5/23/2008
Old May 23, 2008 | 07:42 PM
BlakeJ53's Avatar
pmed
Old May 24, 2008 | 04:20 PM
Default Re: HELP! im using an ecu from an automatic in a manuel? (GhostAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GhostAccord &raquo;</TD></TR><TR><TD CLASS="quote">You can convert your auto P06 to manual. I do them all the time. As for the rest of your swap as long as you followed a good Auto to manual swap thread. I'm not 100% on what harness you guys use to do the swaps. Seems like swapping a full harness just to get rid of a few ATM/ TCU & ECU wires would be a lot of work.
Modified by GhostAccord at 10:46 PM 5/23/2008</TD></TR></TABLE>
yea i can solder
Old May 24, 2008 | 04:22 PM
so when u convert the ecu to manuel what do u do? can u give me a link so i can give it to my buddy doing the ecu. or explain how to do it
Old May 24, 2008 | 06:01 PM
If you have a buddy that chips ECU's he probably already knows what resistors to remove and what to jump.
If not it's a pretty simple mod. Here is what he needs to do,
Remove the resistor @ RP17
Replace the resistor @ RP18 with a jumper wire.
Here is a link with pics
http://www.getglitched.com/pgm....html
Old May 25, 2008 | 02:53 PM
thanks alot
Old May 25, 2008 | 04:18 PM
NP
javifunksEK
15
Jun 18, 2010 11:03 PM
Linked
May 21, 2010 09:35 AM
Shonda
Apr 13, 2006 05:29 AM
alky350
Jan 18, 2004 09:38 PM
Smith Wise
19
Aug 13, 2003 11:22 AM
