turbotimer install ... need help bad!
Old May 22, 2008 | 04:03 AM
#Leo#'s Avatar
Default turbotimer install ... need help bad!
Ok, here's the deal...I bought a turbo timer off ebay, and tried to install it. There are 5 wires, red, blue, yellow, brown and black....brown goes to parking brake sensor, black goes to ground...that, I'm positive.
Other three, I can not seem to get them right...I tried a million times, got ignition schemes from internet etc, but can get it to work. It lights up and I can adjust timing etc, but when I turn the ignition off the engine stops running ( I adjusted turbotimer to one minute). I would like to know, anyone driving a 4th gen civic (EF Civic) and done this, which wire from TT to connect to which one in igniton. Help, I'm desperate
Sure there is somebodey that has TT connected on his 4th gen civic!!!
Thank you!
Old May 26, 2008 | 05:38 AM
#Leo#'s Avatar
Anyone? ... there must be somebody with TT on his EF....please!
Old May 26, 2008 | 10:42 AM
hotrod99's Avatar
Default Re: (#Leo#)
turbo timers a big waste of money if you ask me but if you really want heres how to hook it up...
Black=ground
Red=constant 12v
Yellow=ign 1
Blue=ign 2
Brown=E-brake
Old May 27, 2008 | 03:49 AM
#Leo#'s Avatar
2hotrod99> thank you, but I already know that...my problem is that I have 7 wires going out from ignition, and I can not figure out which one to connect to which...so I wanna know if somebody has already done it, just to write me here the pattern, which one to connect to which...
Old May 27, 2008 | 11:07 AM
chimmike's Avatar
Default Re: (#Leo#)
Yank the brown wire to the ebrake, that thing isn't necessary and is more of a PITA.
Old May 29, 2008 | 07:17 AM
#Leo#'s Avatar
I can't believe that there isn't somebody who has a turbotimer on his 4th gen civic!!!!!!!!!!! I still need help
Old May 29, 2008 | 09:49 AM
standbackimapro's Avatar
What years the car?
4th gens dont really have an ignition 1 and ignition 2 like newer cars..
Ignition for an ef is a Black/Yellow Wire
try connecting both ignition wires from the turbo timer to the black/yellow wire
you also may have to cut the black/yellow wire, connect one wire to one end of the cut, then the other wire to the other cut end, but try connect both into the black/yello wire
Modified by standbackimapro at 1:55 PM 5/29/2008
Old May 29, 2008 | 12:33 PM
#Leo#'s Avatar
Thanks, I will try that!
Old May 29, 2008 | 01:21 PM
JSPECSIR's Avatar
Default Re: (#Leo#)
the ign 2 wire can probably go to the acc. wire. thats how it knows you turned the key off and starts to count backwards.
Old May 30, 2008 | 03:00 AM
#Leo#'s Avatar
There are 5 wires from turbo timer... :
BLACK one goes to ground
BROWN one goes to parking brake
RED one goes to 12 V
YELLOW one goes to ignition key on
BLUE one goes to ACC
That's what it says in the installation instructions....
So, you're saying to connect BLUE and YELLOW both to black/yellow in the ignition harness?
Old May 31, 2008 | 03:45 PM
Yah, put the Blue and yellow wire to the black/yellow wire if that dosnt work put the blue one to the Blue/white wire thats the accesory wire.. But try them both to the black/yellow first
Old Jun 3, 2008 | 07:08 AM
Any luck?
Old Jun 3, 2008 | 07:35 AM
welfarepc's Avatar
this guy has been tryin for ever to get this timer working... good luck!
Old Jun 4, 2008 | 12:04 AM
#Leo#'s Avatar
Haven't had any time lately, so I did not try get to it yet. But maybe today or for the weekend.....don't worry, you'll be posted here....
Old Jun 4, 2008 | 06:53 AM
#Leo#'s Avatar
AAARRRGGGHHHHH.....didn't work!
Tried both yellow and blue to black/yellow and tried blue to blue/white.....nothing worked..when I turn the ignition key off the engine stopped every time...now you know why I am trying to get somebody that has a turbotimer on his 4th gen civic to anwser me!!!!....so if you know anybody with a turbotimer on 4th gen civic, please direct him to this topic!!!! I'm loosing my hope slowly
Old Jun 4, 2008 | 07:48 AM
Default Re: (#Leo#)
Try posting this in the EF Forum
Ek4 life
10
Nov 16, 2008 01:33 AM
#Leo#
May 4, 2008 09:30 AM
korney
Feb 19, 2006 11:38 AM
1bar
Apr 27, 2004 02:59 PM
crashtest Sonny
Dec 26, 2003 07:52 PM
