questions about oil lines for prelude.
Old May 21, 2008 | 04:25 PM
92prelude23's Avatar
Default questions about oil lines for prelude.
does it matter which port you use to get the oil to return and drain on the turbo?
Old May 21, 2008 | 04:35 PM
I dont think i made that very clear... Does it matter which side of the turbo is the Oil Feed & Return
Old May 21, 2008 | 05:15 PM
Str8 outta Cliff's Avatar
Default Re: (92prelude23)
Yes
Old May 21, 2008 | 05:36 PM
boostedh22lude1's Avatar
Default Re: (Str8 outta Cliff)
feed line will have threads inverted into the turbo
Old May 21, 2008 | 06:05 PM
Im sorry i dont really understand can you make it more clear? im new at all this and im trying to learn. thank you.
Old May 21, 2008 | 06:25 PM
the oil feed line (oil pressure line) goes on the side with threads (fitting threads into turbo) make sure you run the oil lines vertical, with the feed line on top, the drain will have a threads also but will have 2 bolt holes to bolt a drain tube hopefully that helps
CivicDude2k4
Sep 5, 2006 08:24 PM
SiR99
Jun 11, 2006 09:09 PM
MotorMouth
Mar 20, 2006 07:12 PM
radioren
Feb 7, 2005 08:15 PM
