I got this in my turbo kit ???
Old May 21, 2008 | 03:31 PM
TheOdd001's Avatar
Default I got this in my turbo kit ???
I'm thinking I can toss this... This is for a mass air flow sensor, right???
Old May 21, 2008 | 03:35 PM
laziebun's Avatar
Default Re: I got this in my turbo kit ??? (TheOdd001)
Im thinking you might want keep that if your you want to do more then 11psi....or you can send it to me and it looks like a GM 3bar map sensor
Old May 21, 2008 | 03:37 PM
king06's Avatar
Dont toss it, its a gm 3 bar map sensor, your going to need that if you want to boost more than (dont quote me on this) 11 or 14 psi, thats how much the stock map will read up to.
Old May 21, 2008 | 03:39 PM
chimmike's Avatar
I'll give ya $30 for it.
Old May 21, 2008 | 04:21 PM
Schister66's Avatar
Man U FTW
That's a GM 3bar map sensor which allows you to read 2bar (~29psi) of positive pressure; whereas the stock honda map is a 1.8 bar and reads to about 11psi
Old May 21, 2008 | 04:42 PM
TheOdd001's Avatar
Default Re: (Schister66)
Ohhhhh.... well how does this work with the map sensor? Hahaha Im a fool!
Old May 21, 2008 | 04:51 PM
chimmike's Avatar
Default Re: (TheOdd001)
that replaces your stock MAP sensor dude....but you've got to have a tuning system for it.
Old May 21, 2008 | 04:53 PM
TheOdd001's Avatar
Default Re: (chimmike)
Im getting a p72 with a s300...
Old May 21, 2008 | 05:00 PM
DfwBB6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheOdd001 &raquo;</TD></TR><TR><TD CLASS="quote">Im getting a p72 with a s300... </TD></TR></TABLE>
nice sell the GM map sensor get a hondata or omni plug and play FTW!!!!
Old May 21, 2008 | 05:06 PM
TheOdd001's Avatar
Default Re: (DfwBB6)
After doing some further research I think I just may purchase a hondata or omni 4 bar, plug and play, plug and play... haha so this GM 3bar would probably have to wired into the stock map sensor right? Thanks for the quick responses, this site rocks like I do on Rock Band drums!!!
Old May 21, 2008 | 05:21 PM
boostedcivicsir's Avatar
Mr. Badwrench
what you have will work.
put all your patrs down, step back, read.
then read some more.
it isnt worth nuking a setup because of ignorance.
i mean that in a good way.
the 3 bar will work, but if you are bent on the p and p, the 4 bar will work.
Old May 21, 2008 | 05:39 PM
TheOdd001's Avatar
Default Re: (boostedcivicsir)
Thanks for the advice Sir, I want my setup reliable and lookin clean so I'll spend a little extra... I'm learning as I go. I already have parts that I'm not gonna be using from the kit because I've been doing more and more learning! Thanks for the help everybody... I don't have a trial account anymore!!! Posts galore!!!
crazy_ls_90
Sep 10, 2008 02:26 PM
ekk41
Oct 24, 2007 05:28 PM
SilverPanda
Oct 9, 2007 01:16 AM
EJ8 GSR-T
Mar 29, 2007 06:48 PM
dominate9
Nov 18, 2003 01:04 PM
