Car is dead and has no power! Don't know where to start
Old May 21, 2008 | 10:33 AM
slacks's Avatar
Default Car is dead and has no power! Don't know where to start
I replaced my transmission ground cable two weeks ago and since it's been hard to start. Spark plugs were put in two days ago and still hard to start.
Last night driving home under decent acceleration my speedometer jumped and CEL went off (for the first time ever) and then came back to normal.
Today! Was driving home and it was stumbling really hard under acceleration as if the car was shutting off and on. I got home, pulled in the driveway, and the car completely died....... no lights, power, acc, cranking fuel pump.. anything.
The ecu wasn't fried
battery connections were good.
and no fuses in the engine bay were toasted.
Where do I start with this?
Old May 21, 2008 | 11:24 AM
slacks's Avatar
Default Re: Car is dead and has no power! Don't know where to start (slacks)
anyone?
Old May 21, 2008 | 12:10 PM
wmac's Avatar
I would re-check transmission ground, since thats when it all started.
Old May 21, 2008 | 12:36 PM
slacks's Avatar
Default Re: (wmac)
The ground looks good but the car would at least turn on when the key is turned, regardless of cranking. My mom suggested the battery being completely drained since there is no kind of mark on it showing when it was installed.
Old May 21, 2008 | 01:06 PM
blkegcoupe's Avatar
From: ....................................................................................................
when i did my clutch i forgot to but my ground back on and it wouldn't start power everything cept no fuel or crank the cel didn't turn on also so i put the back on and it started right up try sanding down a on a piece of metal and attach the ground to that or the block and see if that helps
Old May 21, 2008 | 01:09 PM
slacks's Avatar
Default Re: Car is dead and has no power! Don't know where to start (blkegcoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slacks &raquo;</TD></TR><TR><TD CLASS="quote">The ground looks good but the car would at least turn on when the key is turned, regardless of cranking. </TD></TR></TABLE>
let's do this again
no headlights
no high beams
no hazards
no accessories
no radio
no blown fuses.
nothingg is getting power when anything in this car is turned on.
Old May 22, 2008 | 07:37 AM
slacks's Avatar
anyone else? I want to know before i have to bum a ride to autozone and get a new battery
i'm figuring it's that as when the horn button is pressed it sounded REALLY weak. the relay relay was louder than the horn itself
Modified by slacks at 8:47 AM 5/22/2008
Old May 22, 2008 | 07:48 AM
Dasfinc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slacks &raquo;</TD></TR><TR><TD CLASS="quote"> anyone else? I want to know before i have to bum a ride to autozone and get a new battery
Modified by slacks at 8:47 AM 5/22/2008</TD></TR></TABLE>
Bring your alternator and current battery to autozone as well and have the alternator and battery both tested.
Old May 22, 2008 | 07:59 AM
slacks's Avatar
Default Re: Car is dead and has no power! Don't know where to start (Dasfinc)
i was just going to bring the battery for now to see if it's good. there's no time to pull the alternator when there's a job interview within the next two hours lol
but will get on that as a part two (if neeed)
Old May 22, 2008 | 08:55 AM
slacks's Avatar
ok problem solved!
for ***** and giggles I sanded the terminals and copper ring where it connect the battery and it started right up.
so much blue-corrosion stuff
blackfoot
Oct 28, 2013 12:17 PM
dj_5
Oct 5, 2009 05:38 PM
buhda0422
Nov 30, 2007 05:51 PM
Timberland237
Sep 16, 2007 03:30 PM
nighttrain33
13
Jun 16, 2007 10:32 PM
