OEM LSD making lots of noise. is this normal?!?!? PLEASE HELP
Old May 20, 2008 | 05:25 PM
redline870's Avatar
Default OEM LSD making lots of noise. is this normal?!?!? PLEASE HELP
ok i just put a jdm b18c engine and lsd tranny out a japenese 96 integra type r in to my 93 del sol. when making turns at low speeds it makes a popping, clunking, almost binding sound. is this normal? it can be felt through the wheel and actually seen at the wheels. i changed the tranny fluid with genuine honda fluid, and bought brand new(not remans) cv shafts and it still makes noise. when turning at higher speeds it does not do it, and when warmed up it doesnt seem to do it as much. is this normal for an oem lsd? i was told if i put limited slip additive in the tranny that it would go away but i dont want to put any foreign fluid in my tranny unless i know its gonna fix the problem. can somebody please help me out with this???
Old May 20, 2008 | 05:30 PM
JOHN WAYNE's Avatar
Default Re: OEM LSD making lots of noise. is this normal?!?!? PLEASE HELP (redline870)
definitely not normal...i was going to say check your axles, but youve already done that...
Old May 20, 2008 | 06:03 PM
iheartintegras's Avatar
my lsd is making a similar sound. I tried the lsd additive, didn't help. I ended up buying a new lsd, just waiting to put it in.
Old May 20, 2008 | 07:26 PM
redline870's Avatar
Default Re: OEM LSD making lots of noise. is this normal?!?!? PLEASE HELP (JOHN WAYNE)
i have read in a few places that this is normal?? what the hell.
Old May 20, 2008 | 08:17 PM
def. not normal for an OEM lsd
Old May 21, 2008 | 06:22 AM
CW-ITR's Avatar
Default Re: OEM LSD making lots of noise. is this normal?!?!? PLEASE HELP (iheartintegras)
Hard to tell if it is normal or not with just your discription. A sound recording will realy help here. If you modulate the throttle input during slow turn, this will happen or if you are in the wrong gear, this also happen. Try going with smooth throttle input to see if it sound and feel better.
Old May 21, 2008 | 12:00 PM
94VTECoupe's Avatar
Default Re: OEM LSD making lots of noise. is this normal?!?!? PLEASE HELP (CW-ITR)
NO this is NOT normal. An LSD should indeed place some resistance on the wheels, that's its purpose, (and so you might feel it a bit in the steering wheel when making lock-to-lock turns) but it should do this very smoothly. Its not normal, like a lot of people will say.
I know this is on a completely different vehicle, but my mom's jeep was hard to drive because it was jolting around quite a bit when parking and etc. and was making noise like that, but after getting it replaced its super smooth now... I would have yours looked at.
Old May 21, 2008 | 12:09 PM
Mugen Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redline870 &raquo;</TD></TR><TR><TD CLASS="quote">ok i just put a jdm b18c engine and lsd tranny out a japenese 96 integra type r in to my 93 del sol. when making turns at low speeds it makes a popping, clunking, almost binding sound. is this normal?</TD></TR></TABLE>
Are you sure it's an OEM diff? The noises you describe sound indicative of a clutch-pack type LSD.
Old May 21, 2008 | 02:25 PM
Rishiras's Avatar
that is corect, the oem lsd will not make any noise, there must be something else inthere like KAAZ, ATS or Quaiffe.
On my ITr 99 jdm its silent, which has the helical LSd oem.
Jack the car and rotate the wheels, it should rotate against each other if OEM Helical, if KAAZ etc, its both forward or both backwards depends how u rotate.
R
Old May 21, 2008 | 06:34 PM
itr1235's Avatar
don`t know but check to see if the CV not separated where it goes into the tranny
Old Dec 3, 2008 | 11:21 AM
BringIT's Avatar
Was a solution ever found for this?
Is the noise present turning both left and right?
one^g
14
Nov 14, 2005 12:31 PM
SC-MK1
Jun 18, 2005 04:09 PM
Gsr_Rob
Dec 24, 2004 07:00 AM
chambersef8
Apr 1, 2004 06:03 PM
JDM97R
11
Jan 23, 2004 01:17 PM
