Turbine rotation
OK I got myself a T3 60 trim (the one off the thunderbird/sho's). It was cleaned up and such before i bought it. problem is that the turbine inlet it pointing the same direction as the oil outlet. Anyway so I got the bolts loose to rotate the housing... it doesn't wanna move. Tried spraying some WD40 in there... no movement. Any ideas?
First of all which bolts are un doing? make sure your not losening the bearing section...cuz that wont do u any good. You should loosen the the bolts that have the metal clamps that hold the housing together.
If your sure ur doing it right....mybe some wd40? i dont know how safe it is to use a type of break free agent on turbos.
Edit:
u already said wd40
[Modified by Cramerox, 5:32 PM 7/15/2002]
Edit:
u already said wd40[Modified by Cramerox, 5:32 PM 7/15/2002]
yah i do but i don't think they're that good...
this is of the first T3 60trim i had (never made it onto the car)
http://www.tiora.net/~civicryda2k/?p..._60_%28sold%29
then here's the new one:
http://www.tiora.net/~civicryda2k/?p...Fturbo_project
what were thoes injectors listed under at the parts store? and what parts place did you get them from?
It sounds scarey, but I had to use a rubber mallet and then a small prybar to get it off...even the second time before it was installed! just be careful, I don't think I fudged anything.
hehe j/k i tapped it gently with the hammer
DigitalFusion
Jun 19, 2002 06:06 PM
had to tap at it with a lil hammer
