Turbine rotation
Turbine rotation
OK I got myself a T3 60 trim (the one off the thunderbird/sho's). It was cleaned up and such before i bought it. problem is that the turbine inlet it pointing the same direction as the oil outlet. Anyway so I got the bolts loose to rotate the housing... it doesn't wanna move. Tried spraying some WD40 in there... no movement. Any ideas?
1 Post
Re: Turbine rotation (CivicRyda2k)
First of all which bolts are un doing? make sure your not losening the bearing section...cuz that wont do u any good. You should loosen the the bolts that have the metal clamps that hold the housing together.
If your sure ur doing it right....mybe some wd40? i dont know how safe it is to use a type of break free agent on turbos.
Edit: u already said wd40
[Modified by Cramerox, 5:32 PM 7/15/2002]
Re: Turbine rotation (Cramerox)
Re: Turbine rotation (RioNinja)
yah i do but i don't think they're that good...
this is of the first T3 60trim i had (never made it onto the car)
http://www.tiora.net/~civicryda2k/?p..._60_%28sold%29
then here's the new one:
http://www.tiora.net/~civicryda2k/?p...Fturbo_project
yah man the compressor size is pretty big for a t3. the turbine side is only a .48 a/r good for my sohc
Re: Turbine rotation (CovertFI)
what were thoes injectors listed under at the parts store? and what parts place did you get them from?
It sounds scarey, but I had to use a rubber mallet and then a small prybar to get it off...even the second time before it was installed! just be careful, I don't think I fudged anything.
Re: Turbine rotation (ion_four)
DigitalFusion
06-19-2002 06:06 PM
