Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
What PSI should i use!!??
Old May 19, 2008 | 03:56 PM
LambertTeam5150's Avatar
Default What PSI should i use!!??
Okay so heres my setup i own a 2004 civic lx
Engine Mods:
AEM alt and power steering pulleys
Speed demon Crank shaft pulley
Aem Cam gear
Venom 400 control Module
JDM Turbo Charger T/3
Well i need to know what my max limit psi i can use so i dont ruin my engine thanks guys!!
Old May 19, 2008 | 04:25 PM
hondacivic03's Avatar
i wouldnt put more than 5 to 10
Old May 19, 2008 | 04:37 PM
kenbo21's Avatar
Default Re: What PSI should i use!!?? (LambertTeam5150)
I have a 2004 civic ex...with the d17a2...I have a fully custom t3/t4 turbo on it...all the work was done by myself other than the tuning..Right now I am running 6 psi with a stage 2 excedy clutch and act lightweight flywheel. If you are looking to go over 6-8 psi than you will need to start thinking about building up the bottom end as it can only handle about 10 psi max..
So if you have a daily driver like mine and you dont want to blow it up, I would keep it at 6 psi..Trust me it is a lot faster than stock..
Old May 19, 2008 | 04:39 PM
EM2Brande's Avatar
not to sound rude but whats a JDM T3, sounds crappy to me. As far as you ?, no more than 6psi unless you build the bottom end, have machine work done to the head.
Old May 19, 2008 | 07:18 PM
Curiouz_G's Avatar
ehh, the only thing i would worry about is your IM above 10psi. in all honesty, with a good tune, youll be safe below 10psi with a stock IM.
Old May 19, 2008 | 08:48 PM
toyomatt84's Avatar
Sanji
Use this first: https://honda-tech.com/zerothread?id=1897200
If you still have a question unanswered, ask in that thread.
EJ1chevelle
Sep 24, 2007 01:23 PM
OrangeBoost
Apr 17, 2006 05:03 AM
blackoutcivic
May 14, 2005 02:02 PM
mat
May 18, 2004 03:27 PM
ludelvr
Nov 3, 2002 11:33 AM
