LS distributor...
Old Jul 15, 2002 | 09:11 AM
EGHatchy's Avatar
Default LS distributor...
I need a obd0 dist. for my obd1 LS motor...what distributor COULD work with this? Is it possible to just wire up the obd1 dist. to run obd0?
Old Jul 15, 2002 | 09:49 AM
Jeff C's Avatar
Default Re: LS distributor... (EGHatchy)
the dist will be ecu specific, not motor specfic...so what ecu are you using
90-91 teg obd0
92-95 teg, 94-95 sol obd1
96 + teg, 99-00 si obd2
Old Jul 15, 2002 | 10:25 AM
EGHatchy's Avatar
Default Re: LS distributor... (Jeff C)
im using a obd0 ECU...and I have a obd1 dist...the question im tryin to ask is, I know the plugs on the obd0 and obd1 distributors are different, so is there any way I can wire up the obd1 distributor to the obd0 ECU? that way I wont have to buy a obd0 dist...
Old Jul 15, 2002 | 03:01 PM
Newman's Avatar
New User
The internals (which is what matters here) between non-OBD and OBD-1 distributors are different. The only other distributor that is similar/same as the 90-91 LS distributor are the 89-91 JDM SiR distributors, that come on 1st gen B16 motors (they're exactly the same with the same internals, just different arms and mounting points). If you try to run an OBD-1 distributor with your non-OBD ECU, it's not going to work.
Now, when you go OBD-1 and OBD-2, the internals are the same... just plugs are different. That's why people buy either one and just repin the plugs to fit their needs.
Old Jul 15, 2002 | 09:49 PM
EGHatchy's Avatar
Default Re: LS distributor... (Newman)
thanks, thats exactly the answer I was looking for.
7rrivera7
May 14, 2014 03:25 AM
ryanangelo212
Mar 18, 2013 12:23 AM
AzCRX
Apr 15, 2007 04:23 PM
highvelocitynyc
Aug 17, 2003 10:17 PM
Bontke
Jun 1, 2003 09:51 AM
