D16z6 head Y7 block Problems
Old May 19, 2008 | 01:52 PM
NVmyEK's Avatar
Default D16z6 head Y7 block Problems
i recently did the mini me swap. it was running good for a while, but just this morning it started acting up. when coasting in any gear. id grab hard when you applied the gas and let off rough when i let off the gas. also to mension oudda the gear if i slightly hit the gas id hit rev limiter (almost like a rev control) at around 1800- 2000 rpm..
( i have OBD1 Dizzy on the head. and the P2P ecu.. is that the problem? possibly defult mode?)
Old May 19, 2008 | 02:29 PM
Aquafina's Avatar
You need to convert to OBD-I and use the P28. How do you expect it to run good when you're running the wrong ECU for the cam you have?
Old May 19, 2008 | 03:24 PM
NVmyEK's Avatar
Default Re: D16z6 head Y7 block Problems (NVmyEK)
i do have the p28 ecu but no conv. harness. do you think it will eliminate all this?
Old May 19, 2008 | 03:43 PM
Aquafina's Avatar
Yes. I got my boomslang harness from Kingmotorsports.
You probably need to redo your timing as well. If you set TDC by the mark on the crank pulley, then you're off 4 degrees as the Y runs off 12* and the Z runs off 16*. Set TDC by the piston instead.
Old May 19, 2008 | 03:59 PM
NVmyEK's Avatar
Default Re: (Aquafina)
yeah kingmotorsports is a good place. i live 10 min away hehe. um yeah. i have it at about 4.5 degrees off right now. so should that be good?
Old May 19, 2008 | 04:02 PM
Aquafina's Avatar
Put a wooden bbq skewer with sharpie marks on it in cyl 1 and bring it to TDC. Then look at your cam gear. That should tell you roughly how close you are.
Old May 19, 2008 | 04:03 PM
NVmyEK's Avatar
Default Re: (NVmyEK)
yeah its 4.5 degrees advanced on my cam gear.
Old May 19, 2008 | 04:15 PM
Aquafina's Avatar
Cam gear should be set correctly when cyl1 is at TDC.
Old May 19, 2008 | 04:32 PM
NVmyEK's Avatar
kay. so do u think thats the reason my car is acting up all of a sudden?
Old May 20, 2008 | 11:39 AM
NVmyEK's Avatar
like i said. it only happens once in a while. usually when the engine is warm. also it feeling almost like a trans problem too Help?
Old May 20, 2008 | 05:16 PM
Aquafina's Avatar
Throwing any codes? CYP will make it act funny when warm if its malfunctioning.
Old May 20, 2008 | 08:07 PM
NVmyEK's Avatar
CYP?
Old May 20, 2008 | 08:09 PM
Aquafina's Avatar
cylinder position sensor
Old May 20, 2008 | 08:10 PM
NVmyEK's Avatar
how to fix that?
Old May 20, 2008 | 08:16 PM
Aquafina's Avatar
Are you throwing a code for it? I'm guessing you are.
Old May 20, 2008 | 08:22 PM
NVmyEK's Avatar
idk if i am.
Old May 20, 2008 | 11:37 PM
Aquafina's Avatar
Check to see.
midorigreenmobi
10
Mar 30, 2014 03:42 PM
AlfieRoach
16
Dec 15, 2010 01:58 AM
gsrcivic9
Dec 14, 2009 10:05 AM
Frost7177
Nov 4, 2009 09:05 PM
bigwill_2004
Jul 27, 2007 09:19 PM
