moan/grind under load during launch
Old May 19, 2008 | 09:19 AM
95streetciv's Avatar
Default LOUD moan/grind under load during launch
Stock D16z6 ex trans.
I've got this loud grinding/moan coming from the trans when I take off from a stop.
If I gas it hard, and realease the clutch simultaneously right off the line from stop it will make a loud moan/grind then the tire will chirp and I'll take off. No noise if i take off slow.
I replaced both axles, and got a stage 2 clutch, still same noise under load at take-off. Real annoying when i'm trying to beat someone off the line, and it sounds like somethings going to give.
Help!
Modified by 95streetciv at 11:01 AM 5/19/2008
Old May 19, 2008 | 10:06 AM
sky7's Avatar
Default Re: LOUD moan/grind under load during launch (95streetciv)
my first guess- I could be wrong. The bearings in your trans are done. there is an amazing writeup in somewhere in here about replacing trans bearings and a great explaination on how they all work- there is more to it thatn you thought.
try searching mainshaft or countershaft bearing, or somebody can throw up a link.
njracer
Apr 1, 2008 02:28 AM
Hondaciv95VX
17
Dec 18, 2006 08:11 AM
Golden
Dec 9, 2004 05:42 PM
calipornya
Nov 23, 2004 08:14 PM
